Anyone with VAG-COM in London area?
2.2 I5 20v turbo - 315 bhp
AAH!
Post by AAH! » Mon Jan 17, 2005 2:57 am
I'm trying to get to the bottom of a low boost problem (0.5bar max) as discribed in this thread I started on the S2 Forum:
http://www.s2forum.com/forum/showthread ... #post72877
So far I have changed the hoses to samco's, fitted a new forge dv, fitted a new WGFV, tried unplugging the MFTS, checked the TPS & CTP, pulled Blink codes (1111 came up: Engine Control Module Malfunctioning - Poor ground connection. Also can suggest that the ECU has been chipped/mapped/tampered with), output tested the sensors. New hall & speed sensors fitted 5 months ago and poor earth connection rectified (i was told). Pressure test kit, new Lambda & new MFTS in the post.
So far, no luck.
Basically it looks like the next stage of the process will be pulling the codes with VAG-COM as I need more detailed info than blink codes can provide.
Can anyone help with VAG-COM in the London area?
All the best....Angus
RS2 +
maRS2
RE: Anyone with VAG-COM in London area?
Post by maRS2 » Mon Jan 17, 2005 3:30 am
Try to blank the hose going to N75 then you should get really high Boost
- if yes clean or change N75
- I f not you have problem with you wastgate (always open)
Green 95 RS2 TT(twin torsen) Mihnea chip, full 3" custom exhaust, forge dump valve, 18x8 boxterS, Rose joints top mounts, alloy sub frame, powerflex bushes,Bilstein,Neuspeed 19mmRS4 rear ARB, rear V8 Torsen, Removed (AC,Aux Rad,spare wheel and tools)
AAH!
Post by AAH! » Tue Jan 18, 2005 1:46 am
To "fix" a low boost problem all the hoses to the WGFV/N75 were disconected and then joined together to give mechanical control of the wastegate rather than ECU control via the WGFV/N75. There was a 1.5bar spring in the wastegate and there was plenty of boost. This was a quick fix to mask an underlying problem. I have now refitted the stock spring and a new WGFV and the low boost is back and I so far have not got to the bottom of it. Have tried the previously mentioned tests with out any joy, therefore the search for a local VAG-COM.
RS2 +
Return to “RS2 (B4) 1994-1995”
