suspension upgrades and effects
2.2 I5 20v turbo - 315 bhp
alastairg
Post by alastairg » Mon Aug 09, 2004 9:13 pm
Konis fitted @ AMD Fantastic !! Settings 1/2 turn on front 1/4 turn on rear from softest (QST suggest 1/2 rear) And dyno run 315bhp 338lbft no bad @ 10yrs with ambient temp @ 32C
RS2 'an estate car named Desire'
hiltron
Post by hiltron » Tue Aug 10, 2004 8:28 am
Hi alistair.
So the way I see it. QST suggest 25% front and rear. You have yours set. 25% and 12,5%. Other suggestions on the forum are 50%front and 60% rear. According to my instructions with the shocks, 2 full turns is hardest. How do yours feel. Firmer than standard. A lot firmer, or similair. How is ride over bumps? Plush enough for the missus?
95. RS2 RHDrive. Polar Silver. Stock Standard
quattroturbo
Post by quattroturbo » Wed Aug 11, 2004 1:19 am
The adjustment on Koni Sport dampers only effects rebound. In my experience with any quattro equipped car, setting the rear dampers to 60% from soft reduces pitching and understeer considerably. In my on quattro cars the Konis are set to 100% at the back. The only drawback with very firm rebound settings is jacking down on bumpy roads (when the damper compresses and doesn't have enough time to rebound before the next bump).
With regard to the Ur quattro top mounts - it will be one of the best modifications you can do to improve feel, roadholding and sharpness. Just in case you did not see it above; part number is 857 214 323B. Don't let the dealer tell you that number has been superseded. This top mount has to have this number and a blue marking (not green or grey).
quattroturbo
Post by quattroturbo » Wed Aug 11, 2004 1:23 am
CORRECTION: Ur quattro top mount number is 857 412 323B.
alastairg
Post by alastairg » Wed Aug 11, 2004 5:47 am
hiltron wrote:Hi alistair.
Much improved on standard. Only slightly firmer, better low speed ride on poor surfaces. Just better rebound control making uneven surfaces more bearable which in Edinburgh is needed
Doug_RS2
Post by Doug_RS2 » Wed Aug 11, 2004 8:29 pm
alastairg wrote: uneven surfaces more bearable which in Edinburgh is needed
You need tractor wheels to make the roads in Edinburgh more bearable - the worst city I have ever been in for potholes and generally crap roads.
quattroturbo
Post by quattroturbo » Thu Aug 12, 2004 3:32 am
You should try the goat tracks we have in NZ that are referred to as roads.
hiltron
Post by hiltron » Thu Aug 12, 2004 5:02 pm
Installed my Koni's yesterday. Compared rebound to standard Boges before installing. Found 25% was too fast. Set them on 50% front and 60% back. Hard high speed cornering flatter, more controllable, stable and feels like I can up the limits. Drive on bumps also plusher. Replaced top mounts when I bought car. Didn't know about blue ones.
Installed shocks myself. Saw I need to replace front wishbone rubber bushes. Will order from powerflex.
Return to “RS2 (B4) 1994-1995”
