i know some of you are using hi degree/lift aftermarket camshafts.here are some questions for you
-what degree/lift do you use for fast road use?
-what brand?
-where to get?www?
-is only camshaft enough does audi valve spring tolerate hi lifts?up to?
is there any company have these parts as kit like cam-lifters-springs-locls ?
-gains?hp?torque?
-rpm range?
-disadvantages ? comsumption?idling?
-prices
-is it hard to install?
thnx for your help
PERFORMANCE CAMSHAFTS!
Quattro
Re: PERFORMANCE CAMSHAFTS!
Timucin, for up to 450 HP, the RS2 cams are perfect, you don't need anything else!
So save your money and spend it on something more useful, on turbo motors, cams have very rarely to be changed before 100+HP more than stock, at least on Audis...
Hope this helps,
Mihnea
Hope this helps,
Mihnea
