lowering the car-which springs?
i am planning to lower the car .will use eibach springs.any experience with that?any other suggestions? [img]images/graemlins/s4anogaro.gif[/img]
Quattro
- markcanderson
Re: lowering the car-which springs?
My other car runs with Eibach Springs and yellow Koni adjustable dampers. I find the Eibachs a little on the soft side. Have your considered H&R springs?
'94 Audi RS2 Avant (Polar Silver)
'01 Saab 9-3 TiD S Coupe. (Abbott tuned)
I didnt realise Eibach made springs for the S2/RS2. Ive heard good things about the H&R's though
Bullshit baffles brains
Greg i think you are right.i have just checked their web site and they dont tell anything about s or rs cars.here is their application list
Model Chassis/Body Beg Year End Year
A4, Sedan, 2WD, 4 Cyl.
B5 11/1994 01/1999
A4, Sedan, 2WD, 6 Cyl.
B5 11/1994 01/1999
A4, Sedan, Quattro, 4 Cyl.
B5 11/1994 01/1999
A4, Sedan, Quattro, 6 Cyl.
B5 11/1994 01/1999
A6, Sedan, Quattro, 6 Cyl.
C4 12/1990 03/1997
why i can make mistake is: i use this brand very often,they have a distributer here in turkey.
i will check h&r now.will post the result here,if you are also interested in springs
they might have it.here is a list from a webpage
B5 11/1994 01/1999
B5 11/1994 01/1999
B5 11/1994 01/1999
B5 11/1994 01/1999
C4 12/1990 03/1997
Quattro
002. Koni sports and Eibach Pro-kit package 1995 - 2001 Eibach lowers 1.4 in.front and 1.3 in. rear. Specify engine size. 769.00 Add to Wish list
Add to Cart
004. Koni sports and H&R springs package 1995 - 2001 H&R lowers 1.25 in. front and 1 in. rear. 799.00 Add to Wish list
Add to Cart
006. Koni sports and B&G springs package 1995 - 2001 B&G lowers 1.25 in. Specify engine size. 749.00 Add to Wish list
Add to Cart
010. Koni sport shocks 1995 - 2001 Set of 4. Koni has free shipping. 621.60 Add to Wish list
Add to Cart
014. Bilstein Sport shocks 1995 - 2001 set of 4, Sport series 469.00 Add to Wish list
Add to Cart
017. Sachs shocks 1995 - 2001 Set of 4. 599.00 Add to Wish list
Add to Cart
018. Eibach Pro Dampers 1995 - 2001 Set of 4. 489.00 Add to Wish list
Add to Cart
020. Eibach Pro-kit springs 1995 - 2003 Lowers 1.4 in. front and 1.3 in. rear. 245.00 Add to Wish list
Add to Cart
030. B&G springs 1995 - 2001 Lowers 1.25 in. 209.00 Add to Wish list
Add to Cart
035. Neuspeed sport springs 1995 - 2001 Lowers 1.25 in. 199.00 Add to Wish list
Add to Cart
040. Neuspeed race springs 1995 - 2001 Lowers 2 in. 209.00 Add to Wish list
Add to Cart
045. H&R sport springs 1995 - 2001 Lowers 1.3 in. front and 1 in. rear. 259.00 Add to Wish list
Add to Cart
047. Eibach Pro-system 1995 - 2001 Includes struts/shocks and springs 679.00 Add to Wish list
Add to Cart
048. Eibach Pro-system plus 1995 - 2001 Includes Pro-system with front and rear sway bars. 949.00 Add to Wish list
Add to Cart
050. Koni coil over kit 1995 - 2001 Koni has free shipping. 973.00 Add to Wish list
Add to Cart
051. B&G coil overs 1995 - 2001 Threaded body coil over kit. 1099.00 Add to Wish list
Add to Cart
060. Eibach front sway bar 1995 - 2001 Front sway bar is 30mm. 259.00 Add to Wish list
Add to Cart
065. Neuspeed front sway bar 1995 - 2001 29mm 169.00 Add to Wish list
Add to Cart
070. Neuspeed rear sway bar 1995 - 2001 19mm 219.00 Add to Wish list
Add to Cart
073. Neuspeed short shifter 1995 - 2001 Neuspeed short shifter. 259.00 Add to Wish list
Add to Cart
075. Power Slot front brake rotor 1995 - 2001 set of fronts 189.99 Add to Wish list
Add to Cart
080. Power Slot rear brake rotor 1995 - 2001 set of rears 169.99 Add to Wish list
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Quattro
Timucin - where does this list of parts come from?
Chasman
RS Blue 1994 Audi RS2 Standard (so far)
I was going to fit H&Rs to mine but checking their 2004 application details on their web site they aren't there any more - they were when I looked a month ago - we may have missed the boat... [img]images/graemlins/confused.gif[/img] I've emailed them for confirmation.
Chasman
gimme some time will find and post the part numbers for you
Quattro
I have H&R coilovers on my Corrado. They are a very well engineered package. H&R always specify the model to their coilover kits, so the dampers are matched to that vehicle. For example, they do seperate kits for the Corrado 16v, G60 and VR6 - as H&R specify different dampers for each. Koni on the otherhand just do one coilover kit, but their dampers are adjustable. I have a mate with Koni coilovers on his Corrado and that is definitely a little softer than mine on H&Rs. Both corner very flat and feel very controlled. The H&Rs do give a very firm ride, which is great on smooth surfaces but can be a little harsh on bumpy B roads in the UK. [img]images/graemlins/crazy.gif[/img]
Certainly coilovers give a wide range of height adjustment, but you then have to be careful of wheel contacts in the arch and watch the front spoiler. [img]images/graemlins/blush.gif[/img]
AmD generally recommend using either H&R or Eibach springs with Koni T/A dampers if not going the coilover route. I was under the impression that Eibach's were generally a little harder than H&Rs in most VW/Audi applications - but I have no experience of either on a RS2.
It may be worth talking to or emailing AmD or QST on the subject as I am sure they will be able to give you guidance from their vast experience.
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
I plan buy KWSuspension. Many guys at Germany use it! Look at:
http://babelfish.altavista.com/babelfis ... ari2_1.htm
(click at >>>)
and
http://www.kwsuspension.de/e_version/ge ... ewinde.php
(click at >>>)
and
I've had a reply and H&R still do springs for the RS2 the part number for a set of 4 is 29969-1 [img]images/graemlins/jump.gif[/img]
The supplier for the UK is:
Motorsport Wheels
10-11 Thurrock Park Way
RM18 7HZ
Tilbury, Essex
telephone: 01375-489500
fax: 01375-489501
e-mail: tilbury@mswuk.com
Motorsport Wheels
RM18 7HZ
Tilbury, Essex
fax: 01375-489501
Chasman
