new exhaust on monday
2.2 I5 20v turbo - 315 bhp
timucin
Re: new exhaust on moday
Post by timucin » Thu Dec 11, 2003 11:33 pm
you are very lucky bros!!! you live in the middle of everything [img]images/graemlins/smile.gif[/img]:):)
good luck to you
[img]images/graemlins/thumbs.gif[/img]
Quattro
s6plus
Post by s6plus » Fri Dec 12, 2003 8:26 am
wow, that looks nice and solid! must sound perfectly
I guess you got a lot of dirty/dusty roads overthere [img]images/graemlins/033102bigblink_1_prv.gif[/img].....
David
DAVIDP20V
Post by DAVIDP20V » Fri Dec 12, 2003 10:09 am
looks sweet ! [img]images/graemlins/clap.gif[/img] [img]images/graemlins/thumbs.gif[/img] [img]images/graemlins/clap.gif[/img]
is there no issue with lack of back pressure on turbos ? [img]images/graemlins/spineyes.gif[/img]
a friend of mine had a powerflow exhaust fitted to his BMW Z3 roadster with only one silencer on each back box and cats remove etc etc, a rolling road reckoned he was loosing around 12-20 bhp due to no back pressure ???? [img]images/graemlins/nodder.gif[/img]
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Greg_S
Post by Greg_S » Fri Dec 12, 2003 6:53 pm
Have you got bracket fitted onto the centre section where the cats were since all the weight will be on the turbo and wastegate for the exhaust otherwise.
Greg
Bullshit baffles brains
timucin
Post by timucin » Fri Dec 12, 2003 7:47 pm
looks like they didnt (from the pics) will check tomorow
Quattro
timucin
Post by timucin » Mon Dec 15, 2003 8:50 pm
-center is ok.its attached.
pls listen to my story;
remember i told you there was no difference after exhaust, actually i got worse. the problem was damaged hose.today it was fixed.i tokk the car from service -AYYY AYYYY AYYYY it was running like mad-dog!!! the best untill now . i saw more then 25 psi on peak!!! i was shifting without leaving the gas pedal and it was like this:
WOOOOOOOOOOOOOOOOOOOO-TOFFFF WOOOOOOOOOOOOOOOOOO-TOFFF
i was excited and ordered lots of new parts then.
but after........
an unidentified a***ole hit and run to my lovely rs-zwei [img]images/graemlins/smile.gif[/img]
but np i will fix it asap
Quattro
NIKOLAS
Post by NIKOLAS » Mon Dec 15, 2003 11:15 pm
So Timusin
Are you happy with the new exhaust? Did you get any noticcible gain when you first removed the cats? Because i am thinking of removing them too. IS the rear part of your exhaust custom made? Any poinnts that need attention?
timucin
Post by timucin » Tue Dec 16, 2003 9:16 am
result: i am happy with the new exhaust
performance:yes there is a difference ,better now,noticable gain
sound:may be disturbing on a long journey
rear part: custom made ; but you can acces similar sizes with better looks (even-carbon) from states. prices start from 120 usd to 300usd
attention:try not to touch any other pipe,hose when doing the front part (downpipe etc)
removing cars only: when i only did that before i didnt notice any performance gain.they dont have solid like other cars ,they are sporty from factory
-also try to keep them as close as they can to the car body.this is for speed-bumps if you have
good luck
Quattro
