Audi Rs2 engine tuning do's and dont's
2.2 I5 20v turbo - 315 bhp
timucin
Post by timucin » Sat Oct 04, 2003 3:54 pm
ok here is an idea most of the rs2 owners i know are highly interested in engine tuning.this is the most common thread/post on all audi forums.why dont we all agree on one list? that would be a cool reference for the all RS2 family
members.
i think companies are also a bit confused about this.some of them says you need bigger turbo for even 350hp some of them goes 400 with the standart turbo etc.Who is right who is wrong?which company is better?reasonable?
with all experiences and some research i am sure we can make the perfect list.
here are the three most common options:
350hp
-you do need only a software/chip
400hp
-bigger turbo
-fuel pressure regulator 4.3 bar
-sport air filter
-software
-sport cats or no cats(which is possible in my country [img]images/graemlins/wink.gif[/img] )
450 hp
-bigger turbo
-software
-sport air filter (open)
-racing camshafts
-76mm straight pipe exhust with only one straight silencer
-bigger injectors
-(on this application none of the companies talk about s1 intake.they are chancing the intakes over 500hp applications.i am not sure on that.)
me; i am going for 450 hp application.will post all the results.
i am ready to hear all your ideas including part-supplying-company suggestions..
thnx
Quattro
markcanderson
Re: Audi Rs2 engine tuning do's and dont's
Post by markcanderson » Sat Oct 04, 2003 5:45 pm
The problem tends to be on how conservative and safe the tuning companies want to be.
For example, the replacing of the turbo unit for something else before another company does it. All turbos have an optimum flow. If you make it boost higher than the optimum flow rate, it will produce more heat...not usually a problem, but at a certain point, it will be producing a lot of heat for a specific boost, where as the other turbo for a specific boost won't be producing as much heat.
Now this is important when tuning for reliability. Because excess heat causes earlier detonation and premature wear. If the engine management system starts to detect knock as the intake temps rise, the system will start opening the wastegate earlier tapering the boost more... so what you can end up with is a car that can boost to x BAR, and produce say 380HP on the standard turbo, but only for a very short period of time, under optimum circumstances (i.e. 0 degrees C ambient at sea level on 100 octane..)
Other tuners would rather that you get your full 380HP every time, even with heat soak....
thats why these lists don't really work... and thats why there is such a difference in methods.
'94 Audi RS2 Avant (Polar Silver)
'01 Saab 9-3 TiD S Coupe. (Abbott tuned)
Greg_S
Post by Greg_S » Sat Oct 04, 2003 6:42 pm
above 420hp you need to think about changing the RS2 manifold to sport quattro or tubular etc becuase it becomes restrictive then and if push it too hard can be left with the S2 manifolds use to have with exhaust valves 1 & 5 over heating. Which is why porsche uprated the manifold in part.
Bullshit baffles brains
timucin
Post by timucin » Sat Oct 04, 2003 11:21 pm
is there anybody here who did engine tuning and fully satisfied?!?
if yes what is the application?
Quattro
timucin
i am talking about 400hp's
Quattro
Doug_RS2
Post by Doug_RS2 » Sun Oct 05, 2003 10:46 pm
I have an S2 but we are aimning for 420bhp maybe 440bhp hopefully in a weeks time - I will tell you how we get on.
timucin
Post by timucin » Mon Oct 06, 2003 1:45 am
cool! i am looking forward to hear from you
[img]images/graemlins/rocker.gif[/img]
Quattro
Return to “RS2 (B4) 1994-1995”
