Hallo,
I need if someone knows the settings for the wheel alignment for the Audi Rs2 front and rear.
Thank you
Wheel Alignment
RE: Wheel Alignment
RS2 Suspension Alignment Values
FRONT:
Caster front:
Recommended value +2,10º
Max difference left/right +0,30º -0,30º
Camber front:
Recommended value -0,45º
Toe front:
Recommended value +0,07º
Max difference left/right +0,05º -0,05º
Toe total front:
Recommended value +0,14º
Max difference left/right +0,10º -0,10º
BACK:
Camber back:
Recommended value -0,40º
Max difference left/right +0,20º -0,20º
Toe back:
Recommended value +0,05º
Toe total back:
Recommended value +0,10º
There you go,
Rob
FRONT:
Caster front:
Camber front:
Toe front:
Toe total front:
BACK:
Camber back:
Toe back:
Toe total back:
There you go,
Rob
RE: Wheel Alignment
Thank you very much
Best regards
Best regards
