Alloy Flywheel
2.2 I5 20v turbo - 315 bhp
brucelubbers
Alloy Flywheel
Post by brucelubbers » Mon Apr 23, 2007 1:42 pm
Along with other Audi projects I am blessed with a Ur Quattro which has among other mods a 6 speed 'box. I was using a RS2 clutch & pressure plate with a one off alloy flywheel.
The problem i have is that she is just tearing the friction material off the pressure plate. I have put this down to having no damping on either the plate or flywheel (and driving like a ****)
Have any of you guy's had similar problems with your RS2's fitted with alloy flywheels and how did you get around it. Thanks
Corey
RE: Alloy Flywheel
Post by Corey » Mon Apr 23, 2007 2:01 pm
You need a sprung clutch, the RS2 item is unsprung due to the OE dual mass flywheel
Corey
brucelubbers
Post by brucelubbers » Mon Apr 23, 2007 2:12 pm
Thanks Cory, kinda worked that out, Any idea of what will fit??
Corey
Post by Corey » Mon Apr 23, 2007 3:47 pm
You have quite a few choices. Go and have a look over on the S2forum where we can help you
Corey
