Aux rad area coolant leak
2.2 I5 20v turbo - 315 bhp
alastairg
Post by alastairg » Fri Feb 09, 2007 4:58 pm
I have had a persistent coolant leak for over 6 months. With normal daily driving it is minimal. But it can be significant if I stress the cooling system (hard and or long drives) enough to drop the level from max to min in a few days.
Car has had new main radiator (end last year) new auxillary rad (2004) new after run coolant pump (last year) most of the coolant pipework renewed during my ownership (last three years).
All clips tight.
At present and all along the only area always to have evidence of dried coolant is the 3 way piping to the aux rad. This pipe was new end last year (previous one had split, you could see it weeping coolant ,wrong side of clip !!) and I thought I had solved it.
It passes pressure testing at dealer but clearly under pressure coolant is getting out. Could the rad have a small hole/split or would this be obvious ? I have spent time with the engine on after a long run trying to see a leak but no luck. The underside of the lower aux rad pipe has been damp but no more than that. I have repositioned that pipe and replaced clip.
Could this be an air lock ???
It seems worse when A/C on. Does that change coolant pump speeds ??
Greg_S
RE: Aux rad area coolant leak
Post by Greg_S » Fri Feb 16, 2007 1:22 pm
Putting the aircon on wont change the coolant pumt speed since that is driven by the timing belt. Just changed my aux rad because it had a small leak, could only tell because it had got discoloured in places
Bullshit baffles brains
AAH!
Post by AAH! » Sat Feb 17, 2007 1:58 am
Faulty filler cap?
In theory the cap should rattle when shaken, which shows the pressure relief valve is working. Maybe the valve is stuck open?
Cheap to replace from Haulfrauds.
Angus
RS2 +
afhgus
Post by afhgus » Sat Feb 17, 2007 5:07 pm
what about the expansion tank. Mine had a split near the hose bit. Had to get a new one.I have heard also that they can use some water and the air con uses a bit??
M690LYY Volcano black,130000 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, new exhaust/head gasket, pulls like a train. for sale soon
