Best tyres?
TinTin RS6
Best tyres?
Hi guys, couple of quick questions.
When you get a puncture on the RS6, do you have to change both tyres, all four tyres or just the one?
I know with previous cars, it's suggested to change at least 2 or all four to keep the 4wd computer system running correctly.
Secondly, what are the recommended tyres to use?
It currently has 275/35/ZR20 102Y Michelin Pilot Super Sports on.
And lastly, where's the best prices place to buy them?
Thanks in advance.
Thanks in advance.
Re: Best tyres?
It really depends on the wear per axle. If the other tyre on said axle is fairly new then replacing a single tyre of the exact same model will be fine, but I'd suggest 25% wear being the maximum. If more than this then replace both.
I'd suggest not switching tyre make unless you're changing all 4 tyres, but you'll be hard pushed to better the MPSS.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
- RossDagley
- Top Gear
Re: Best tyres?
Thank god for that. I was just thinking we hadn't had a tyre thread yet this month!
Axle pair should always be the same make/model. As above - 25% or so difference and you should consider switching.
Pilot Super Sports are pretty much the ultimate daily driver / spirited driving tyre. Stay with them.
Previously:
Previously:
TinTin RS6
Re: Best tyres?
I've just been told by Audi that it should have Pirrelli P0 RO1's on it.
Tyre wear on the good back tyre is down to about 4/5mm
So I will need to change both rear tyres.
But can I change the rear two to pirrelli's and still keep the michelins on the front?
Thanks again guys
Thanks again guys
- RossDagley
- Top Gear
Re: Best tyres?
Ignore the Audi idiot who's never driven both. Please!TinTin RS6 wrote:I've just been told by Audi that it should have Pirrelli P0 RO1's on it.
Thanks again guys
Whatever you do, do NOT move from PSS's to PZeros. You'll hate it.
Previously:
Previously:
Re: Best tyres?
Tyre talk in the Track Day and Meet section ha
Re: Best tyres?
Good advice from Ross.RossDagley wrote:Ignore the Audi idiot who's never driven both. Please!TinTin RS6 wrote:I've just been told by Audi that it should have Pirrelli P0 RO1's on it.
Thanks again guys
I reckon we should make a separate Tyres sub-forum, and let bam_bam moderate. Could be entertaining!toyneg wrote:Tyre talk in the Track Day and Meet section ha
TinTin - So how much tread do the 3x good tyres have left on them?
Tyreleader have good prices. Also worth a look; camskill, oponeo, and apparently kwik-fit mobile have some good deals sometimes (as reported on the forum)
2007 RS4 B7 Avant
Re: Best tyres?
The "25%" thing is not accurate. There are limits/tolerence around rolling diameter but you will not reach them as long as the tyres are within the legal limits. i have posted the source information for this before if you want to search for it.TinTin RS6 wrote:Hi guys, couple of quick questions.
Thanks in advance.
It is true about tread patterns though, dont mix them
Also that pirelli are <beep>, stay with your PSS
TinTin RS6
Re: Best tyres?
Sorry if it the wrong thread, I'm new to forums as well as RS6's! LolS4WON wrote:The "25%" thing is not accurate. There are limits/tolerence around rolling diameter but you will not reach them as long as the tyres are within the legal limits. i have posted the source information for this before if you want to search for it.TinTin RS6 wrote:Hi guys, couple of quick questions.
Thanks in advance.
I've stuck with the super sports, but decided to change both tears just to be on the safe side
Re: Best tyres?
Yeah don't listen to the idiot from Audi, mine came with Dunlops from the factory and some come with continentals. All of which are labelled as R01 Audi specific but as stated above the michelins are far superior.
