Santa Pod RWYB Sunday 20th May
ZeroK66
Post by ZeroK66 » Tue May 15, 2007 3:34 pm
I used one when I went down the runway (0-160 vid clip) and it worked fine... problem is the seats, rearview mirror etc get in the way and the mount I used didnt work so well with the sunroof either... but different mounts be different I suppose.
GrahamS4
Post by GrahamS4 » Tue May 15, 2007 4:31 pm
Anyone on the vag-com vs. timing gear at Santa Pod (or similar) comparison?
ZeroK66
Post by ZeroK66 » Tue May 15, 2007 10:33 pm
I wouldnt mind doing this... I could give it a try I guess? But in the moment you are sooo hyped up that remembering to get everything together in time is a bit tricky. Ideally a passenger needed but that wont help times. It does not have to be a all out best time attempt I guess, be good to compare pod time vs. VAG-0Com time and see how accurate it is.
DavidT
Post by DavidT » Tue May 15, 2007 11:21 pm
I'll have a go at this, and a fixed video camera on the dash, facing back etc. as well.
With the vag-com, you just need to press go when you are staged and it starts measuring when you move.
Do they allow passengers ?
I'm not sure how many runs we can get if it's busy.
Seen the weather forecast :( average I guess. http://uk.weather.com/weather/local/NN2 ... 2=7xa&y=11
GrahamS4
Post by GrahamS4 » Wed May 16, 2007 7:30 am
No passengers at Santa Pod. There is a good FAQ etc here: http://www.rwyb.co.uk/
Nice write up on the staging (lights) process and what you are meant to do. Basically once green you go when you are ready.
Weather looking bright for Sunday by BBC, but too soon to tell: http://www.bbc.co.uk/weather/5day.shtml?id=2846
Now it's been a while since I have been so this is a suggestion, but it worked for the group the few times I have been. Some of us are spectating only and we are arriving at different times but I suggest everyone enters the venue as shown, not stopping at the car park. It will be much nicer if we can try and get parked up together. On a regular RWYB day this is highly likely to be possible.
The picture looks like it was from a busy event - marquees etc up everywhere. It wont be like that. The blue cross I have marked I think is the greasy spoon cafe on site. If we at least all park around this side of the venue, hopefully we will be able to group together when not in the queue for runs.
MarkB
Post by MarkB » Wed May 16, 2007 8:32 am
So does that mean we should all say we are running so as to not be sent in to the car park?
Mark
Matthewbaldry
Post by Matthewbaldry » Wed May 16, 2007 10:05 am
They dont usually operate the main carparks for RWYB events so you should be able to drive Straight round. There is plenty of parking area at the cafe/pits side of the track. The area at the bottom of the pic where cars are parked is all tarmaced now.
See you all there.
Make sure you all take your licences with you
I'm not sure if I'll be running my car, my mate Toby will be racing his Caddy so I might stick to video duty but then I suspect I'll get bullied into racing at some point during the day :D
Quattro Rocket Science
MarkB
Post by MarkB » Wed May 16, 2007 2:32 pm
GrahamS4 wrote:GrahamS4, Spectating
RSVI (Trying to butter the missus up and get permission)
ScottyBoy, Spectating
Ads4, Spectating (although could be tempted on the day!).
GrimReaper, Spectating
S4TAN, Spectating ...
SimonS4MTM, spectating (hangover status dependant)
Peakz, Spectating
MarkB, Running
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
My car won't be ready for this so I'm moving myself from the running to spectating list :( I probably won't even be coming in the Audi :oops:
Peakz, Spectating
MarkB, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Mark
Daz
Post by Daz » Wed May 16, 2007 2:39 pm
I'll be there too but just spectating I expect.
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Cheers,
Daz :D
Audi RS4 Cabriolet with added Milltek - Gone :(
az
Post by az » Wed May 16, 2007 5:00 pm
Following on from the TSN S3 post I will be there with my S3 (8P)
Looking forward to it.
AZ
stevie_d
Post by stevie_d » Wed May 16, 2007 10:54 pm
I've also popped over from TSN, I'll be running with Az!
Peakz, Spectating
MarkB, Spectating
Daz, Spectating
Zerok66, Running
S4woody Running
Nickb, Running
DavidT, Running
Doug_S2 Running
Azure (TSN) Running
Stevie_d (TSN) Running
DavidT
Post by DavidT » Wed May 16, 2007 11:01 pm
Welcome Stevie_d & Azure and thanks for posting here.
Fingers crossed for the weather, the turnout will be great :)
stevie_d
Post by stevie_d » Wed May 16, 2007 11:18 pm
Cheers David, should be a good day out. Hopefully won't be too busy as last time I went I had to queue for about 2 hours...
Ads4
Post by Ads4 » Thu May 17, 2007 7:56 am
My car won't be ready for this so I'm moving myself from the running to spectating list I probably won't even be coming in the Audi
What have you done this time Mark????
Adam.
MRC B5 S4 Avant.
MarkB
Post by MarkB » Thu May 17, 2007 9:50 am
I planned to get my exhaust and intercoolers sorted before this but waited a month for some parts from Demon Tweeks. Nothing fancy, just some pipe and fastenings. I've canceled the order now :( Get the bits elsewhere...
Mark
Users browsing this forum: No registered users and 123 guests
