Power Loss B5 RS4(UPDATE)
Posted: Thu Jul 05, 2012 5:19 pm
by JJ-RS4
I just bought a 2001 RS4 and It did not feel faster than my E36 3.2 M3 so I took it to the dyno.
It made only 352hp and 449nm.
The car has remap and exhaust with decat. It has 228000km.
What are the possible causes of lack of power? I was expecting something around 400hp.
The timing belt service will be done shortly. What to look for?
Re: Power Loss B5 RS4
Posted: Thu Jul 05, 2012 10:15 pm
by neckarsulm
Where does one start?
EGT(s)
MAF
Do a
Vag Com scan and post the results.
If there are no codes, do a live data run with
VCDS logging MAF and post here
Posted: Wed Jul 25, 2012 9:26 am
by JJ-RS4
There are too many fault codes that we have detected.
16524 Oxygen Sensor B1 S2
P0140-35-10- No activity-ıntermittent
17861- Exhaust Gas Temp Sensor 1 (G235)
P1453-35-10- Open or Short to plus- intermittent
17521-Oxygen Sensor; B1 S1
P1113-35-10 -İnternal resşstance too high- intermittent
17547 Fuel Trim: Bank 2 ( Add )
P1139 -35-00 System too rich
17545 Fuel Trim: Bank 1 ( Add )
P1137-35-00 System too rich
17537 Fuel Trim, Bank 2 ( Mult )
P1129-35-00 System too rich
Posted: Wed Jul 25, 2012 12:45 pm
by guy
Looks like replacement EGTs and a Maf as well as the Cambelt service! Have the lambdas ever been changed?
Posted: Thu Jul 26, 2012 2:58 pm
by JJ-RS4
I will try to change them as soon as possible.
I have no clue ıf lambda sensors have been changed or not...
Posted: Fri Jul 27, 2012 7:15 am
by neckarsulm
Definitely EGTs, a fault with those will reduce boost
Lambda faults don't tend to reduce power in the short term
Posted: Tue Jul 31, 2012 10:52 am
by JJ-RS4
neckarsulm wrote:Definitely EGTs, a fault with those will reduce boost
Thanks for the info. Do I need to replace both of them.....It seems that one of it is faulty??
Those things are really expensive
Posted: Tue Jul 31, 2012 2:42 pm
by Mr V10
Welcome to RS ownership.
Posted: Tue Jul 31, 2012 10:14 pm
by neckarsulm
you can replace just the faulty one (unlike turbos)
Posted: Fri Aug 10, 2012 5:01 pm
by JJ-RS4
Posted: Fri Aug 10, 2012 5:05 pm
by JJ-RS4
neckarsulm wrote:you can replace just the faulty one (unlike turbos)
Hi,
One of my friend will come from Germany this month. I will order the EGT repair kit and MAF. As he will bring the parts, I will ask him to get another things....for example: Set of spark plugs? Anything else?
Re: Power Loss B5 RS4(UPDATE)
Posted: Sat Sep 15, 2012 7:21 pm
by JJ-RS4
MAF-EGTs and spark plugs were changed by new ones....fuel trim and EGT fault codes were all been cleared. The vehicle seems to operate better than before as well as less fuel consumption. But we have a new problem.....when the engine is on boost about 5000rpm, It sometimes feels sluggish and cuts power suddenly....the car behaves like a NA 2.0 rather than 2.7T.
We took the car to the mechanic where the parts were installed and diagnosed it. Fault codes are right below. The car has decat.
16815/P0431/001073 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
17521/P1113 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
I am not sure these faults are really effective on performance cut, the car has decatted as I mentioned.
This is the last fault code and most suspicious !!!!
17964/P1556 - Charge Pressure Control: Negative Deviation
As I searched for the fault code, I got some info from the net.
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzle
Has anyone faced with the same problem? What to look for initially? Leaks or N75?
Thanks for your help
Posted: Sat Sep 15, 2012 9:16 pm
by MrGeneric
N75 valve... Had same prob and dough changed it and it was fine... Is the n75 also know as boost pressure sensor?
