no life
Posted: Fri Apr 02, 2010 12:07 am
by dazp
i put this on electrical forum aswel.
is there any silly things that could drain battery over night ?
checked the obviuose things like lights !
i also put a new battery on just incase,
and vag com came up with brake light switch faulty, so changed that.
but just thought i`d ask if there is any silly things that we would not normaly check.
Posted: Fri Apr 02, 2010 9:26 am
by Steviescottish
My car also has a minor battery drain. It is off to the paint shop for a respray but when i get her back the only way to pin point the battery drain is to turn off the ignition, go to the fuse box with a multi meter and check every fuse to see which one is still pulling power.
My battery would drain completely if left for 2 to 3 weeks unstarted.
That doesn't happen very often but i don't like the idea that there is an obvious electrical fault.
Happy Easter by the way.
Posted: Fri Apr 02, 2010 1:15 pm
by Virdee Autos
Have any of you got tracker fitted? This will to a certain extent drain the battery.
Posted: Sat Apr 03, 2010 4:30 pm
by Steviescottish
My car has had a tracker in the past. Never crossed my mind that it could be that! Smart thinking dude!
I assume it would continue to pull power if connected to the network or not??
Any ideas where a tracker gets it power?
Posted: Sat Apr 03, 2010 8:14 pm
by Virdee Autos
Tracker is connected to one of the circuits on the car, and plus has a back-up battery, which is rechargeable.
