Page 1 of 2
what would cause real poor fuel economy??
Posted: Thu Dec 03, 2009 10:33 pm
by maxrs4
any ideas?! im guessing fooked lamdas would- im getting no faults on vagcom!
what else
Posted: Thu Dec 03, 2009 10:38 pm
by pegbox7
what do you call poor ?
Posted: Thu Dec 03, 2009 11:45 pm
by UKS4APR1
Coolant Temp Sensor ?
(tells ECU engine is cold all the time so overfuels)
Re: what would cause real poor fuel economy??
Posted: Fri Dec 04, 2009 12:01 am
by ollys
maxrs4 wrote:any ideas?! im guessing fooked lamdas would- im getting no faults on vagcom!
what else
stuffed maf?
RE: Re: what would cause real poor fuel economy??
Posted: Fri Dec 04, 2009 7:55 am
by maxrs4
im gettin about 20 miles for a tenner, i have replaced the coolent temp sensor.
Posted: Fri Dec 04, 2009 9:02 am
by Contigo
Does the car get up to temp?
Posted: Fri Dec 04, 2009 9:45 am
by Norrs2
what else
stuffed maf?
Agreed, this can cause real bad consumpstion. Won't always show up on VAG-COM either! My S2 was only getting 150 miles on a tank when the MAF was shot, and that was taking it easy!
Posted: Fri Dec 04, 2009 9:58 am
by juice
how long you had the car?
if you have just aquired it, i would change the maf, dv's to 710n's spark plugs and that would leave put lamda last to change.
Re: RE: Re: what would cause real poor fuel economy??
Posted: Sat Dec 05, 2009 9:25 pm
by maxrs4
juice wrote:how long you had the car?
not very long had new dv's and had new spark plugs and had one lamda changed i dont remember its had a maf its also had new coolent temp sensor
what should the plugs be gapped to?! :)
RE: Re: RE: Re: what would cause real poor fuel economy??
Posted: Sat Dec 05, 2009 9:39 pm
by DutchRS4
vacuum leaks. Check/replace all vacuum hoses, if not already done.
Re: RE: Re: RE: Re: what would cause real poor fuel economy?
Posted: Sun Dec 06, 2009 11:30 pm
by maxrs4
Contigo wrote:Does the car get up to temp?
not really when i just cruise about i might just move off the min- if i open it up or its a warm day runs about the middle
DutchRS4 wrote:vacuum leaks. Check/replace all vacuum hoses, if not already done.
are we talkin the upper ones like going to an from the actuators fuel pressure reg etc?
there are two vacuum valves of some sort that have been remved at the back of the engine but are left plugged in!?
Posted: Sun Dec 06, 2009 11:58 pm
by DutchRS4
This sounds strange. I can't visualise what you're meaning here. Could you maybe post us a pic?
RE: Re: RE: Re: RE: Re: what would cause real poor fuel econ
Posted: Mon Dec 07, 2009 12:11 am
by rickoshea
Sounds like the Thermostat or sender unit. I'd change the sender unit first - otherwise it's a £700 bill for a new thermostat :(
Re: RE: Re: RE: Re: RE: Re: what would cause real poor fuel
Posted: Mon Dec 07, 2009 3:41 pm
by DutchRS4
Are you talking about the coolant or oil temp gauge? Good to know before starting to replace things.
Posted: Tue Dec 08, 2009 12:07 am
by maxrs4
i have replaced the coolant temp sender unit already,
neither the water or oil get very warm unless ur giving it beans the oil is what id expect prob 70 if just cruising the water runs very cool, most of my other cars have warmed up to bout 90deg and stayed there unless in traffic or getting death, the rs moves just off the min on the water temp guage. today i did about 14 miles and it didnt really move
it looks like a jammed open thermosat but why 700 quid!!!!??
