Fault codes...
Posted: Fri Aug 21, 2009 9:35 am
by rhunter203
Ha s anyone had the following fault codes:
P0300 Random Multiple cylinder:
Misfire detected
P0304 Cylinder 4:Misfire Detected
Rob
Re: Fault codes...
Posted: Fri Aug 21, 2009 9:53 am
by rtd
rhunter203 wrote:Ha s anyone had the following fault codes:
Misfire detected
Rob
check this link rob;
http://wiki.ross-tech.com/index.php/16684/P0300/000768
RE: Re: Fault codes...
Posted: Fri Aug 21, 2009 12:54 pm
by TopBear
Yep, I had that regularly, just before my cams needed replacing.
It could be a multitude of things causing this though. Duff coil pack(s), amplifiers, injectors, MAF.........
You should be seeing more than 1 cylinder misfire (in your case cyclinder 4) for a 'Random\Multiple' DTC code though
Posted: Fri Aug 21, 2009 1:56 pm
by Nige_RS4
I saw that on my RS - plugs needed tightening (seems to be quite a common thing!)
Posted: Fri Aug 21, 2009 2:34 pm
by rhunter203
Oh dear lets hope its one of the cheaper options...
Posted: Fri Aug 21, 2009 4:46 pm
by TopBear
If you measure and log blocks 15 and 16, you can 'watch' which cylinders are misfiring, and at what revs they misfire, to help you narrow down the focus a bit.
Re: RE: Re: Fault codes...
Posted: Mon Aug 24, 2009 4:34 pm
by rhunter203
TopBear wrote:If you measure and log blocks 15 and 16, you can 'watch' which cylinders are misfiring, and at what revs they misfire, to help you narrow down the focus a bit.
Thanks. The main problem I have is the car has only misfired once!
Posted: Mon Aug 24, 2009 4:50 pm
by TopBear
rhunter203 wrote:TopBear wrote:If you measure and log blocks 15 and 16, you can 'watch' which cylinders are misfiring, and at what revs they misfire, to help you narrow down the focus a bit.
I take that to mean it's only logged misfires once as DTC's, and you've cleared them and they never came back?
Perhaps poor quality fuel is to blame then?
RE: Re: RE: Re: Fault codes...
Posted: Mon Aug 24, 2009 5:20 pm
by rhunter203
The misfire happened after I gave the car full beans from cold – I know this is a no no but I pulled out to late. The car stuttered
then the engine management light came on, I immediately stopped the car and turned off the engine, I left it for 5 mins, started
up and drove very gingerly back home – the light has never come back on nor has the car misfired again.
I haven't cleared the codes yet - booked into MRC for Thursday and thought it best if I leave well alone!
