Part number required for Y pipe seal
Posted: Wed Mar 25, 2009 1:26 pm
by N11LS_J
Gents
I have a boost leak from one of the inlets on the 'Y pipe', does anyone have the part number as Audi state you can't buy the seal, and need to replace the entire pipe???
Hoping someone can help, please see exactly which seal is required in picture below
thanks in advance
Nils
RE: Part number required for Y pipe seal
Posted: Wed Mar 25, 2009 4:50 pm
by wjn
078 133 148 D o-ring, costs about € 2,25 ex VAT. This is the one between the Y-intake duct and the pressure pipe.
Posted: Wed Mar 25, 2009 4:52 pm
by wjn
See also attachment:
Posted: Wed Mar 25, 2009 4:59 pm
by andream88
Just solder them together.
The charge pressure pipes are tightened with only 1 bolt, they will always leak ;)
Andrea
Posted: Wed Mar 25, 2009 8:12 pm
by N11LS_J
Thanks for that wjn
Andrea, shouldn't there be some flex in the joint hence the seal?
Posted: Wed Mar 25, 2009 9:07 pm
by andream88
nope.
those charge pipes are connected to the SMICS (Intercoolers) with silicon hoses.
cheers
Posted: Thu Mar 26, 2009 12:22 am
by jimbo1234567
nills .you will always get leaks from those joints . the only way to get rid of the leaks is for someone to weld them round= no more leaks.l the charge pipes are bolted to the cam covers and the link pipes to the intercoolers are flexis. if you go down this route you need to take both charge pipes off and remove the o rings then put it back together and get the charge pipes tacked to the ypipe in situ then take it off again and get them seam welded :biggrin2:
Posted: Thu Mar 26, 2009 11:42 am
by TopBear
Mines is leaking as well, Grizz picked it up at the last service.
Who's had their's welded already, does it involve pull the front end forward to disconnect the alloy charge pipes?
Posted: Thu Mar 26, 2009 7:34 pm
by rsmonkey918
Mine were given a hefty seeing to with silicone sealer when MRC detected a leak in the same place- sorted! Can see an alloy weld fracturing at some point.....
Steve
Posted: Thu Mar 26, 2009 8:28 pm
by Virdee Autos
rsmonkey918 wrote:Mine were given a hefty seeing to with silicone sealer when MRC detected a leak in the same place- sorted! Can see an alloy weld fracturing at some point.....
Steve
Silicon - cheap and cheerful! Does the job!
Posted: Thu Mar 26, 2009 8:31 pm
by A20LEE
job for the weekend i think.
Posted: Thu Mar 26, 2009 8:41 pm
by jimbo1234567
they are a bitch to get off though
