Page 1 of 3
Any ideas what's rattling at the front of engine when hot?
Posted: Sun Mar 08, 2009 7:52 pm
by neckarsulm
My car seem mechanically in good health apart from a weak thermostat and a rattle from the front of the engine when its warm.
It sounds like a classic noisy bearing on one of the pulleys, hard to describe specifically but it sounds similar to the noise a TDI makes at idle but obviously not as loud! I'd say it seems more over to the passenger side than drivers side.
Doesn't seem to be air con related so can rule that out.
It's done 30k since last belt change when it had just 2 tensioners replaced in addition to the water pump and the cambelt itself.
Should anything else have been changed as part of the cambelt change that could be on its way out at 104k miles? I gather auxiliary belt tensioner is one possibility and some sort of idler?
Posted: Sun Mar 08, 2009 8:08 pm
by sherpa
Other way round for me, i have a rattle i think coming from one of the pulleys but goes when engine gets warm.
Posted: Sun Mar 08, 2009 8:12 pm
by grizz
There is a idler on the right side of the engine that drives the viscous fan.
Posted: Sun Mar 08, 2009 8:23 pm
by neckarsulm
Thanks Grizz, does it do that all the time the engine is running?
Posted: Sun Mar 08, 2009 8:32 pm
by grizz
yes
Posted: Sun Mar 08, 2009 9:11 pm
by neckarsulm
yes
makes a lot of sense
Posted: Tue Mar 10, 2009 9:00 am
by neckarsulm
Had a look/listen yesterday and it sounds like it's under the timing belt cover on the nearside, is there anything in there that could make that noise?
Got the front bumper off yesterday, well get into 'service position' today.
Posted: Tue Mar 10, 2009 9:03 pm
by Virdee Autos
Take the aux belt tensioner off, and see that.....more than likely bearings in that will be shot! Although not sure if that will be your cause.
Posted: Tue Mar 10, 2009 9:40 pm
by neckarsulm
Cheers Virdee.
Got the front off and will investigate tomorrow.
It's never had an aux belt tensioner or probably a few other bits that specialists would change during a service.
Will report back tomorrow.
Good time to sort washer leak, repair & paint bumper, investigate why the horn sounds like its from a 2CV, grease oil cooler unions (one looks a but crusty but dry), do thermostat, secure centre bumper grille, oil change.
Posted: Tue Mar 10, 2009 10:18 pm
by Virdee Autos
Seems to be the same old common problems
Had to do my centre grille, when I did my cambelt! Pesky stupid clips!
And my horn sounds like 2CV too......they have a high and low tone horn. I'm suspecting one of mine is not working hence the 2CV sound!
Posted: Tue Mar 10, 2009 11:26 pm
by neckarsulm
Must be a noggy thing
Posted: Tue Mar 10, 2009 11:58 pm
by Virdee Autos
LOL....!!!
Posted: Thu Mar 12, 2009 12:04 am
by imolas4uk
run it with the aux belt off and check the noise is still present before you strip the rest
Posted: Thu Mar 12, 2009 8:46 am
by neckarsulm
Thanks! Hopefully today...
Posted: Thu Mar 12, 2009 10:00 am
by Doug_S2
tensioner, chain, cams??
