Page 1 of 2
Rear calipers serviceable?
Posted: Sun Dec 14, 2008 5:47 pm
by lengster1
Can you get a service kit for the rear calipers? I suspect one of mine has a lazy handbrake mechanism and presume i will have to pop out the piston to get at the ratchet set up?
RE: Rear calipers serviceable?
Posted: Sun Dec 14, 2008 6:17 pm
by Virdee Autos
The only service kit is the caliper seals, which consists of two seal for each caliper. One for the outer protective boot, and one seal inside the caliper.
Posted: Sun Dec 14, 2008 6:22 pm
by lengster1
Thanks Virdee has anyone here ever stripped one? Can it be done?
Posted: Sun Dec 14, 2008 6:38 pm
by grizz
Any caliper can be stripped , a new one is about £150 from audi .
Posted: Sun Dec 14, 2008 6:56 pm
by Virdee Autos
Take the caliper off the car, unscrew the piston. Replace both seals, check for any damage...clean associated parts, and put back together. Bleed the system, and check correct operation.
I think you'll find quite a few B5's have split rear caliper seals. Got to do my own ones when I get time!
Posted: Sun Dec 14, 2008 7:56 pm
by boxerdogted
As long as the chrome hasn't started to come of the piston you wont have a problem.
Posted: Sun Dec 14, 2008 9:55 pm
by lengster1
Ok guys if its the piston thats sticking and a standard overhaul thats no probs at all,i was thinking it was the handbrake mechanism and wasnt sure if it was stripable,will pop the piston out in the morning and take it from there,thanks guys
Posted: Sun Dec 14, 2008 10:03 pm
by grizz
I've never serviced a rs4 rear caliper , What happens with other hand brake calipers is the shaft that corrodes that links the arm to the internal screw thread . This can some times be cleaned up but it will go again as the chrome has gone.
Posted: Sun Dec 14, 2008 10:14 pm
by lengster1
Hmm thanks grizz thats kinda what im expecting when i strip the caliper,If the calipers goosed do you have one by any chance? How much are you doing b7 front calipers and pads for out of interest?
Posted: Fri Dec 19, 2008 2:21 pm
by bneaves
Where do we get the caliper service kit from?
Posted: Fri Dec 19, 2008 7:30 pm
by Virdee Autos
Available from Audi.
Re: RE: Rear calipers serviceable?
Posted: Sat Dec 20, 2008 9:29 am
by dace
Virdee Autos wrote:Available from Audi.
Do you know the part number?
RE: Re: RE: Rear calipers serviceable?
Posted: Sat Dec 20, 2008 1:37 pm
by lengster1
Im off to pick it up shortly will let you know
Posted: Sat Dec 20, 2008 2:56 pm
by bneaves
Ive just ordered a set, £12 something each
Re: RE: Re: RE: Rear calipers serviceable?
Posted: Sat Dec 20, 2008 6:33 pm
by dace
bneaves wrote:Ive just ordered a set, £12 something each
Part number please?
