60k Service what oil,and what SHOULD get done?
2.7 V6 30v biturbo - 380 bhp
lengster1
Post by lengster1 » Sun Nov 02, 2008 6:30 pm
Have been meaning to get my motor down to MRC for 60k service but work commitments mean i only really have time to take it to local stealer,theyve quoted £380 including spark plugs,ive caught them before just about to put longlife oil in it,what is the best castrol oil?im sure at 50k it had the0-30w but think after discussions on here and cam failure problems i had the 5-30w put in at 57k is it whats called castrol edge as im sure thats what the top up bottle is? What else should get done,should they strip and clean the calipers as part of the brake inspection? It feels of late like one is sticking slightly probably due to its lack of use sometimes.I want to know what should be done on a 60k service can you guys give me any pointers so i can make sure its all done.Thanks in advance
dace
RE: 60k Service what oil,and what SHOULD get done?
Post by dace » Sun Nov 02, 2008 8:16 pm
Best oil IMO is Synta Gold 5W40.
A20LEE
Re: RE: 60k Service what oil,and what SHOULD get done?
Post by A20LEE » Sun Nov 02, 2008 8:26 pm
dace wrote:Best oil IMO is Synta Gold 5W40.
what about Mobil 1 5w/40? VAG now use Castrol Magnatec over Synta i noticed last time i was snooping around the local dealer service bay.
Sql_RS4
RE: Re: RE: 60k Service what oil,and what SHOULD get done?
Post by Sql_RS4 » Sun Nov 02, 2008 9:47 pm
I have been using Castrol RS/EDGE 10 W60 - as they say this is a great oil for high performance engines but it does look like not too many of you use it here - why?
TopBear
Re: RE: Re: RE: 60k Service what oil,and what SHOULD get don
Post by TopBear » Sun Nov 02, 2008 11:26 pm
Sql_RS4 wrote:I have been using Castrol RS/EDGE 10 W60 - as they say this is a great oil for high performance engines but it does look like not too many of you use it here - why?
I used it for my last oil change
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
andream88
RE: Re: RE: Re: RE: 60k Service what oil,and what SHOULD get
Post by andream88 » Mon Nov 03, 2008 6:58 am
I'm going to use ROYAL PURPLE 5W40 for the next oil change.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
SimonC
Post by SimonC » Mon Nov 03, 2008 8:17 pm
Nothing wrong with long-life oil. It's the 20k service intervals that do the damage. In terms of cam wear, surely a 0W30 is better than 5W30? My sludge-free engine has enjoyed a Mobil1 0W40 (ie longlife spec) diet for years by the way. The difference being that it gets changed every 5000 miles.
I think the brake inspection will be basic - pad thickness, disc thickness, scoring, corrosion, signs of leaks, etc. I would guess at another 380 quid to have your calipers stripped and cleaned. If your calipers are past their best there are companies who specialise in caliper refurbs and they are generally quite reasonable (EBC used to do it under the Powerstop name. Maybe still do). This is also an opportunity to have ALL of your brake fluid replaced. I have seen main-dealer technicians (not Audi) pull off the reservoir, empty it and refill with clean rather than do the job properly. It seemed to be accepted practise which, when I challenged them, they stated that DOT 4 lasts for much longer than the 2 year recommendtion. Maybe I'm a cynic but I now assume that coolant / brake fluid / spark-plug / air filter / pollen filter changes are only done properly by me.
lengster1
Post by lengster1 » Tue Nov 04, 2008 4:23 am
Hmm mixed opinions then on the oil ?
gb
Post by gb » Tue Nov 04, 2008 12:31 pm
Make no mistake, full synthetic oil is the only and best way to go for a clean engine and longevity. Whilst the brand is less important (I will only use Mobil 1 0-40) the viscocity is paramount.
Overhead cams, turbo engines with intricate valve-trains need to run between 30-40 viscosity to flow freely through the oil galleries. 60 is far to thick and will starve the valvetrain of oil at high revs - very dangerous!
Regards,
GB from downunder
Spunbigendbearing
Post by Spunbigendbearing » Tue Nov 04, 2008 7:05 pm
As previously mentioned; best to change it after shorter intervals;mine gets every 5 K miles fresh oil&filter(oilspec 5W-30).
Users browsing this forum: Majestic-12 [Bot] and 17 guests
