Page 1 of 2
3 new faults in one trip!!!!! Help!
Posted: Sun Aug 03, 2008 2:14 pm
by Norrs2
Folks
Drove my car away from work on Friday after some really heavy rain.
1. Looked down and noticed my Speedo wasn't working (nor mileage recorder) I turned on and off ingnition to no avail.
2. Looked down again some 4 miles on and Engine/ECU warning light comes on. Whilst not that noticable at normal speeds, the car wont rev that much past 6k and starts to splutter.
3. Whilst taking the car up through the revs, the fuel gauge starts to wander from the 3/4 to 1/4, but settles down when revs are low and steady. seems to fluctuate with the higher rpm range.
All other instuments (speedo excluded) are working normally.
Have run Vag-com:-
Address 01 Engine
2 Faults found
17521 - Oxygen (Lambda) Sensor; B1 S1 : Internal Resistance too high
P1113 - 35-10 - - - Intermittent
16885 Vehicle Speed Sensor: Implausile Signal
P0501 - 35-00 - -
Readiness: 0000 0000
Any advice (do I need to buy 2 new Lambda Sensors - Where?)
Is the speed sensor the one beside the drive shaft?
Fuel Gauge?
Thanks in advance
RE: 3 new faults in one trip!!!!! Help!
Posted: Sun Aug 03, 2008 2:47 pm
by Virdee Autos
I would say you definitley need a lambda sensor. Both the front sensors are the same part no., but you need to change the on the RHS...O/S of the car.
As for the other fault, it will probably be the speed sensor that is causing your speedo and odo n/w problems. Don't know where it's located, but you could be right in your guess
Edited to say, that the lambda sensor fault will cause none of the issues/problems you comment on. If you erase it, it will erase, and re-appear after a few days.
Re: RE: 3 new faults in one trip!!!!! Help!
Posted: Sun Aug 03, 2008 3:06 pm
by Norrs2
R33V-Spec wrote:I would say you definitley need a lambda sensor. Both the front sensors are the same part no., but you need to change the on the RHS...O/S of the car.
Are you saying I only need One lambda sensor?
Are you saying that this is not causing the high rpm splutter? If, so why no other fault codes
RE: Re: RE: 3 new faults in one trip!!!!! Help!
Posted: Sun Aug 03, 2008 4:26 pm
by Virdee Autos
Mine had this fault re-occuring everytime I reset it, and it definitley wasn't stopping me going past 6k rpm. Could be a MAF?
Yes you only need one lambda sensor from your test results on VAG-COM
Posted: Sun Aug 03, 2008 8:31 pm
by neckarsulm
I wonder if the speed sensor (aka distance sensor) is causing the reduced rev range?
Norrs2, have you had a clutch of late as this part seems to be on the gear box - I'd def check wiring before buying the part, ETKA pic attached;
Posted: Mon Aug 04, 2008 7:50 am
by Norrs2
neckarsulm wrote:I wonder if the speed sensor (aka distance sensor) is causing the reduced rev range?
Yes, you are correct! The Clutch was replaced about 6 weeks ago, but what could be the problem with the wiring?
Posted: Mon Aug 04, 2008 7:58 am
by neckarsulm
I'm not familiar with this bit of the car but I suspect when the gearbox was removed either the wiring to the sensor has been damaged or the plug hasn't been attached securely and water is getting in causing a short - it looks like an area that'll get very wet in heavy rain.
Re: RE: Re: RE: 3 new faults in one trip!!!!! Help!
Posted: Mon Aug 04, 2008 9:59 am
by Norrs2
R33V-Spec wrote:Yes you only need one lambda sensor from your test results on VAG-COM
How can you tell what side and only one? What aspect of the fault code determined this?
RE: Re: RE: Re: RE: 3 new faults in one trip!!!!! Help!
Posted: Mon Aug 04, 2008 12:08 pm
by neckarsulm
b1 s1 = front + drivers side (bank 1 side 1)
Mine and r33's were B1 s2
Re: RE: Re: RE: Re: RE: 3 new faults in one trip!!!!! Help!
Posted: Mon Aug 04, 2008 5:37 pm
by Norrs2
neckarsulm wrote:b1 s1 = front + drivers side (bank 1 side 1)
Bank 1 - Is that before the Cat?
Posted: Mon Aug 04, 2008 7:24 pm
by neckarsulm
Yes, you can reach the sensor via the engine bay rather than underneath
Posted: Mon Aug 04, 2008 8:49 pm
by Virdee Autos
Bank one (B1) means the RHS/OS of the engine
And the sensor one (S1), means the lambda before the catalyst
HTH
speed senser
Posted: Mon Aug 04, 2008 11:10 pm
by rog893
Hi Guys,
The speed senser is definately at fault, check that the orange seal is intact inside the multiplug which attaches to the senser if this is missing that is why you have water ingress, the reason your fuel gauge and other things are playing around is because one of the earths for the insrument cluster goes through the senser, so if the senser is disconnected this fault happens, hope this helps, once you have fixed it erase all faults and roadtest i.t should be fine
Re: speed senser
Posted: Tue Aug 05, 2008 5:00 pm
by Norrs2
rog893 wrote:Hi Guys,
So hope your right!!!!
By the way, you lot are just ****in wonderful - HUGE Thanks! I'll report back when I get the new stuff fitted.
Re: speed senser
Posted: Tue Aug 05, 2008 9:09 pm
by s4sturge
Top advice Rog, and a cheap fix too - you should charge for that sort of thing!
