Oil in Turbo inlet pipe !
Posted: Fri Feb 01, 2008 3:49 pm
Guys
Had my RS4 into the garage ( again ) and the mechanics continue to tell me my turbo's are needing replaced due to leaks inside the housing that can't be reached ? They have a couple of pics taken showing oil inside the pipe ( dont know which pipe it is as i am not that techy.
I am obviously not keen on replacing the turbos unnecessarily especially as the engine seems to be working fine at the moment , having replaced the MAF, DV's and N75 thingy.
There is also no bad whining noise or any mechanical sounds that give me cause for their being a major turbo failure. No smoke either, just sometimes burning smells from something burning on start up which eventually goes away.
Any thoughts from the expert knowledge base here that could help me in solving the oil leakage issue and working out if the turbos are the problem ?
Unfortunately as i live in Hong Kong, popping over to MRC is not on my list of options... The guys at the garage should know what they are doing as the manager used to have an RS4, so i am inclined to accept their advice, but the expense is daunting...
many thanks
soapy
many thanks
soapy
