Page 1 of 3
Brake upgrade.
Posted: Tue Jan 22, 2008 11:43 am
by nickelvery
I am thinking about upgrading my front brakes in the next couple of months. I know there are so many differnent choices but I don't want to spend a fortune if I can avoid it.
I will be taking my car to have a MRC stage 1 remap and a pre cat gutting too at some point but want to sort everything else out first.
Alot of people seem to put the RS6 calipers on the fronts. I presume you would need to upgrade the discs too?
Is there alot of difference between the standard setup and the RS6 option?
Also with regards to fitting can I not do the upgrade myself or is a mech job?
Thanks in advance.
Nick
RE: Brake upgrade.
Posted: Tue Jan 22, 2008 11:58 am
by jeffw
Nick
You've been in my car which has very similar brake set-up to the RS6 kit....We did some hard stops so you can form your own opinion compared with your standard set-up.
RE: Brake upgrade.
by gb
Its all in the relevant 'Sticky' thread.
too easy!
Re: RE: Brake upgrade.
Posted: Tue Jan 22, 2008 1:03 pm
by nickelvery
gb wrote:Its all in the relevant 'Sticky' thread.
too easy!
Sorry just seen it, feel a little silly now!!
Thank you.
RE: Re: RE: Brake upgrade.
Posted: Tue Jan 22, 2008 2:24 pm
by mikeyquattro
Get the B7 Upgrade from MRC. About £1300 iirc
Re: RE: Re: RE: Brake upgrade.
Posted: Tue Jan 22, 2008 2:30 pm
by nickelvery
mikeyquattro wrote:Get the B7 Upgrade from MRC. About £1300 iirc
Is that front and back and fitting?
RE: Re: RE: Re: RE: Brake upgrade.
Posted: Tue Jan 22, 2008 2:31 pm
by mikeyquattro
Just fronts
Posted: Tue Jan 22, 2008 11:16 pm
by mattykerby01
Just fitted the front B7 setup, calipers and discs with RS6 pads (slighly harder compound), absolutely amazed with the difference and has transformed the car.
The kit is pretty much bolt on and i fitted myself - i also removed the dust shield and used RS6 brake pipes.
Posted: Wed Jan 23, 2008 12:39 am
by don
If you are on a budget I think the Brembo/Porsche Cayenne 6 Piston calipers are still the best value for money. Alot of guys on the forum using these. They are still huge, look the part and arguably stop as well as the 8 pots. Plenty around as well on ebay and other places with the 6 pots being used on other Porsche models. I saw a nice used set the other day on ebay Germany go for 214 Euro (calipers only).
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0184158869
If you do a search on the forum they fit straight on as well and have a lot of pad options.
You can also buy new at:
http://www.ecstuning.com/stage/edpd/pag ... 0Stage%204
Though probably cheaper items available out of Germany.
Posted: Wed Jan 23, 2008 3:43 am
by jimbo1234567
the beauty with those calipers is that they can be used with std discs, my cars got no problem at all stopping.
Posted: Wed Jan 23, 2008 9:31 am
by MarkB
With the Cayenne caliper the disc has to be modified as do the calipers
Posted: Thu Jan 24, 2008 9:02 pm
by quattrokid1
jimbo1234567 wrote:the beauty with those calipers is that they can be used with std discs, my cars got no problem at all stopping.
excellent!! I was going to ask if standard front discs from the B5 RS4 would be suitable with RS6 calipers.... suppose I need more pads though!!
4 each side isnt it
Posted: Thu Jan 24, 2008 10:33 pm
by Virdee Autos
Yep 8 pads in total, and 4 on each side.
Posted: Thu Jan 24, 2008 10:54 pm
by quattrokid1
The UrS4 has this set up, 4 pads each side at the front.
Posted: Fri Jan 25, 2008 12:11 am
by kd
I had the B7 upgrade at MRC and have to say I am very very happy with it. I do normal town driving, may do an occasional track day and for the price and quality its a very worthwhile option
