RS 4 at full chat....?
Posted: Mon May 21, 2007 9:27 pm
by Matt1
If for argument's sake one was able to experience an unmodified (but very clean), 01 reg, 51,000 miler RS4 at full chat on a nice straight, unimpeded road, on a virtually windless day, should one be dissapointed with less than enthusiastic progress from 130 - 140, and then not getting any further than 140mph?
Was under the impression that the limiter cut in at 155mph?
Any thoughts?
RE: RS 4 at full chat....?
Posted: Mon May 21, 2007 9:57 pm
by Nige_RS4
In a word, YES! Unless it was it stuck in 4th gear?
Try changing the MAF (verify this using vag-com)!
Posted: Tue May 22, 2007 7:35 am
by simple1
Should pull the limiter without any trouble at all, which in the case of my car is indicated 170 on the speedo..
Re: RS 4 at full chat....?
Posted: Tue Jun 05, 2007 12:19 pm
by Hiltoa
Matt1 wrote:...at full chat on a nice straight, unimpeded road, on a virtually windless day, should one be dissapointed with less than enthusiastic progress from 130 - 140, and then not getting any further than 140mph?...
...Any thoughts?
I'd definately be disappointed, because my slightly modified (not very clean) 00 reg, 88,000 miler, 1.8T A4 (180bhp ish) would be sat on your tail, if not slowly creeping past you!
I sense great joy to be had if you (for argument's sake) fix the problem and discover what an RS4 really can do... :wink:
RE: Re: RS 4 at full chat....?
Posted: Tue Jun 05, 2007 10:26 pm
by JustinM
With no mods and no change to the limiter you should pull around 165mph (GPS measured). I know, I have done it (not in the UK)
Posted: Tue Jun 05, 2007 11:22 pm
by GardinerG
140 limit in an RS4? No. As Nige says, check your MAF and check for any errors. I've had many ECU errors over the years, but none have caused the check engine light. Also check your hoses/diverter valves for leaks leading to loss of boost.
Posted: Wed Jun 06, 2007 9:29 pm
by blackb1ade
Definite issue - limiter is only at 155 from stock IIRC - mine breeezes straight past 140 like it's not even there.....err 'allegedly'
