aftermarket discs
Posted: Fri Oct 13, 2006 11:41 am
by FLUFF34567
Hi all,
in my quest of finding a rs4 I have been looking at general coss of spare parts etc, i know the brake discs are a bit sprecial on the RS and was wondering what is the ballpark figure of replacement discs... aftermarket or genuine audi????
RE: aftermarket discs
Posted: Fri Oct 13, 2006 11:52 am
by Nige_RS4
Fluff, never seen any like for like aftermarket discs, so unless you go down the RS6 caliper/disc route, stick with the OEM stuff. Maybe cheaper to get them at
www.vagparts.com though
Posted: Fri Oct 13, 2006 11:55 am
by Marlon
Not sure on the uprated discs or pads, the originals are in the region of -
Front discs - £175 + vat each
Rear discs - £155 + vat each
Front pads - £125 + vat
Rear pads - £80 + vat
Marl
Posted: Fri Oct 13, 2006 11:57 am
by MarkB
Or try DSGWAGEN on ebay. He's normaly cheaper or about the same price as vagparts
Posted: Fri Oct 13, 2006 1:09 pm
by FLUFF34567
ok guys thanks for the info - i am going to look at one today and have a drive......
Posted: Fri Oct 13, 2006 1:16 pm
by MarkB
Good luck, have fun
Posted: Fri Oct 13, 2006 7:05 pm
by FLUFF34567
ok i had a drive, was impressed with the performance etc the car looked very clean, full service history etc but there was a small OUTWARD dent just in front of the LH rear bumper - i think it had a scrape at some point, the garage said they would fix that, also noticed that the LH rear light had a slight dip in it, only way to describe is if it got hot and the plastic deformed - i only noticed because i was looking at all the gaps.
But i looked at the brakes and i would say the discs all round need changing - all had a lip on and looked a bit tatty - same with the wheels badly kebed so no care from previous owner. I will give this one a miss, there are about 100 up for sale at the moment so no shortage.
this is it here BTW :
http://www.auto-online.ch/en/AUDI-RS4-A ... 142-2.html
Re: aftermarket discs
Posted: Mon Oct 23, 2006 6:58 pm
by Chubby
FLUFF34567 wrote: i know the brake discs are a bit sprecial on the RS and was wondering what is the ballpark figure of replacement discs... aftermarket or genuine audi????
I would forget about the standard parts, if you want the RS4 to stop and keep stopping then go for an upgrade.
The german approved drilled disc's are an option, but are fairly costly unless you now someone over there.
RS6 is a possibility, although I would go for the RS4 B7 combo, AP racing is good, Movit better but expensive.
My advice try and get the same front and rear, don't mix, if you need more detail I can oblige.
R.
RE: Re: aftermarket discs
Posted: Tue Oct 24, 2006 6:16 pm
by TarmacTerrorist
no need to uprate the rears imho.
movit 4 pot/ap 6 pot fronts work perfectly well with the standard rear set up with no ill effects.
Posted: Wed Oct 25, 2006 2:36 pm
by Särås
Im change my back brakes to the new RS4 (B7)... It fits perfect and it's litle bigger then OEM for the RS4 (B5)...
/Jimmy Särås
