Vibration on steering wheel
2.7 V6 30v biturbo - 380 bhp
OscarH
Post by OscarH » Tue Mar 28, 2006 9:53 pm
Guys,
I have noticed a slight vibration on the steering wheel when I hit about 40mph. It seems to be slightly worse when driving in low gear, though not sure if that is my imagination. When driving faster it is less noticable.
The mrs. has hit the kerb with the left front wheel ca 2 weeks ago, though she claims it wasn't that fast. :x
It was enough anyway to damage the rims (19" MTM Bimoto). I will get it booked in to have it checked out. Any other theories on what it might be?
Thx, Oscar
simple1
RE: Vibration on steering wheel
Post by simple1 » Wed Mar 29, 2006 6:50 am
Sounds like the old bent rim symptoms, and these 19" rims are fairly easy to bend......I hit a small pot hole at very low speed and the rim was beyond repair.
geoffone
Post by geoffone » Wed Mar 29, 2006 3:47 pm
I had a similar problem, but it was worse when braking...
The problems was a warped disk and low tyre pressure on one of the front wheels...
Nickm
Post by Nickm » Wed Mar 29, 2006 4:45 pm
Bent wheels!
dodgydave
Re: Vibration on steering wheel
Post by dodgydave » Wed Mar 29, 2006 5:15 pm
OscarH wrote: The mrs. has hit the kerb with the left front wheel ca 2 weeks ago, though she claims it wasn't that fast. :x
Mrs ??? :shock:
All my Mrs can drive is a shopping trolley - their wheels are mostly bend already!!! :lol:
harry
RE: Re: Vibration on steering wheel
Post by harry » Fri Apr 28, 2006 7:57 pm
I have this problem from time to time under braking from speeds over 60mph cant work it out.
Any ideas oh learned gentlemen?
Practise safe sex & drive a hybrid if you can...
timba
Post by timba » Fri Apr 28, 2006 9:11 pm
Me too getting that small vibration once the brakes have warmed up braking from 60 too
harry
Post by harry » Fri Apr 28, 2006 9:13 pm
I'm sittin on MoVits all corners. You?
timba
Post by timba » Fri Apr 28, 2006 9:35 pm
Standard as just bought the beast :-) but they are reasonably new discs
OscarH
Post by OscarH » Fri Apr 28, 2006 9:39 pm
For me it was indeed a bent wheel. Replaced it and perfect again.
harry
Post by harry » Fri Apr 28, 2006 9:39 pm
hmmm wondered if it was my equipment hopefully someone can shine some light on this
harry
Post by harry » Fri Apr 28, 2006 9:47 pm
Oscar may have knocked tracking/wheel alignment off depending on angle/force of impact. Just a thought.
harry
Post by harry » Fri Apr 28, 2006 9:48 pm
Oscar ignore last entry then. So was it £400 for a new MTM rim?
harry
Post by harry » Sun May 07, 2006 7:45 pm
This situation seems to have resolved over the las wek or so. Wonder if weather related?
simple1
Post by simple1 » Sun May 07, 2006 10:22 pm
Unlikely to be weather related... unless you get a build up of snow inside the wheel........... wrong time of year for that... I had a similar problem after the first and last track day....... on AP brakes. Again turned out to be a bent rim, obviously hit a curb too hard at Donny, wheel has been repaired and the symptoms have gone again..
Users browsing this forum: Bing [Bot] and 135 guests
