Cool, If you have a remap everything is a OK
.... raising the fuel pressure without shortening the injector duty cycle will give you a richer mixture... That was my point thats all...
"Water injection doesn't increase your fuel's octane rating it just cools down the intake, combustion and exhaust temperatures and therefor decreases the chance of detonation. Also it keeps your turbos cooler, which mean they should live longer. "
All True, However the octane rating of methanol is higher than pump fuel thus the overall effect is that running a 30% methanol mix raises octane of the overall mixture by about 4 points... ish this can also allow you to run a tad more ignition advance...
"Also, I wouldn't use more alcohol than necessary to stop the water from freezing as it doesn't do you engine any good."
Hmm, I'll agree to differ. The limiting factor of how much methanol you can use comes from what it does to the resulting fuel mixture.... If you run too much methanol (over say over 40% mixture) the extra fuel burns hotter and it reduces the aquamists effect by reducing the injected mixtures latent heat capacity and there fore totally defeating the purpose of aquamist... (which is cooling!!! not fuel enrichment!)
"Methanol tents to leave white residues on all aluminum parts and increases corrosion of you piston rings and bore walls as it washes away vital lubricant!! " May be true for methanol mega rich environments. Ive not seen any evidence of this on my application and if Im honest Im not bothered about incresed wear! I think you'll find this is a minus point for water injection not for running methanol in water injection!!
"Also the small amount of methanol you're injecting compared to your fuel/air mixture is insignificant and wouldn't affect you performance in the slightest. "
It does beleive it or not. Car feels smoother and help top end and when you following a car using it it even smells cleaner! It all depend on the set up.... In my application (highly tuned VW Polo G40) which is a single jet after the intercooler on a small 4 cylinder effort, it works very well and would deffo reccomend it.
Its all trail and error and everyone will tell you differnet things...
For more info have a squiz here:
http://waterinjection.info/phpBB2/
But I get your point in that the purpose of aquamist is cooling and Not methanol injection! In the S4 I would run 2 pumps and 2 jets after each intercooler... but IO havent looked into that.....
Anyway.... (can you tell Im not busy today).....FPR's Cant help you on direct application but the GTi-R guys seem to like Nismo FPR's and the
Walbro Fuel pumps....let me see.....
I couldnt see any Audi application kits from rally nuts but heres their details..
http://performance.rallynuts.com/render ... -pumps.htm
Hope that helps....
Cheers.
Mark.
PS sorry for the novel....
