Page 1 of 3
BATTERY PROBS
Posted: Wed Jan 21, 2004 1:00 pm
by andnik
Hi Folks,
Just got home from my 2 weeks at work and the [img]images/graemlins/rs4-button.jpg[/img] is totally dead.....not a peep! The battery has totally discharged......this is not the first time............................... do you all have the same problems or where should I start looking for the gremlin that is sucking my power!!!! [img]images/graemlins/29428-red4.gif[/img]NIK
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 1:34 pm
by Bushy
Look for gremlins!
Basically standard Audi wiring should not draw any power, except for alarm system which should last longer that 2 weeks
Quite often it would be an after market alarm or tracker device not connected to the correct feed
I had the same thing last year with my car as I didnt use it for 6 weeks when my back was bad, in the end spent £150 on a gold topped sealed battery, much better especially all the audio etc in my car [img]images/graemlins/1syellow1.gif[/img]
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 2:36 pm
by NigelJ
I've has this twice. First time I got a new battery under warranty and last time, just a few weeks ago, I just charged the battery & its been ok since but I now carry jump leads in case. I suspect its something to do with the alarm system but I'm not sure. However I only left the car a few days not 2 weeks.
NigelJ
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 3:04 pm
by Taipan
I have the same problem on mine, keeps dying after one-two weeks of parking.
I'm about to swap the batteries between the RS4 and the Passat to see if it continues (provided they can be swaped).
In any case, I do have several addition components like the GPS Immobilizer (as all S and RS cars now sold by Audi France have it standard).
Btw, my car was made in July 2001 so that's about 2.5 years of battery life.
Eric
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 3:20 pm
by peterb
My old A4 did this just once. One morning, after about a week of not being used, the battery had absolutely no power. No electricals had been left turned on - just the alarm set. I recharged the battery and it didn't happen again in 3.5 years ownership.
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 4:29 pm
by johneroberts
Deffo an after market device fitted which has been removed and there are no visable signs of it, suggest you look at the feeds to and from the battery, ive had mine 2.75 years and never a moments problem, but there again i dont have any after market stuff fitted.
jr
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 8:15 pm
by kcsun
I have left mine in the garage, locked since Oulten park (November) till last week and it started perfectly. [img]images/graemlins/clap.gif[/img]
Only extra fitted is Trackstar
kc [img]images/graemlins/s4anogaro.gif[/img]
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 8:55 pm
by drjones
If you disconnect the - lead on the battery and put an Ohm meter between the lead and battery terminal you will show a reading which is the drain on your battery, if you then take a fuse out one by one you will isolate the cause and you can then investigate that circuit!
Good A! [img]images/graemlins/thumbs.gif[/img]
Re: BATTERY PROBS
Posted: Wed Jan 21, 2004 11:30 pm
by teknobod
Just to clarify that comment, he means a voltmeter set to the amps range. Do not under any circumstances connect it reading ohms or you'll fry the meter. [img]images/graemlins/thumbs.gif[/img]
Although I do not think the base reading will necessarily be 0 amps. It would be useful to measure a "good" RS4 to give you a starting point.
Andy
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 10:02 am
by drjones
Thanks For that Andy, you are absolutely right long day and all that [img]images/graemlins/smile_smoking.gif[/img]
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 10:19 am
by andnik
OK everyone go and measure yours cars lust for power while parked and post your results lets see who has the most thirsty [img]images/graemlins/rs4-button.jpg[/img]
probably me!! [img]images/graemlins/29428-red4.gif[/img]
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 1:26 pm
by Dippy
No he doesn't. Voltmeter only measure volts. He either means an ammeter or a multimeter set to amps. [img]images/graemlins/tongue.gif[/img]
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 5:02 pm
by Steve_Mc
Both correct as current is a function of voltage [img]images/graemlins/tongue.gif[/img]
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 5:13 pm
by teknobod
Touche!! [img]images/graemlins/spineyes.gif[/img]
There's always one!
You know what I mean.
Having thought about it further, it should also be pointed out that the reading should be taken with the ignition off as this is when the drain is taking place.
Andy
Re: BATTERY PROBS
Posted: Thu Jan 22, 2004 5:17 pm
by JAMES
my car seems a bit slow turning over when i have had the stereo on and engine off.i think the battery has had it,has anybody bought one from audi,if so how much.should i go elsewhere although i would like to stick to audi parts.
