I know this is not the car for this kind of fun, and propably if made several times it will damaged the 4WD system and some other parts, but I´m sure if made once in a while just to feed the addiction wont beat this baby that much
Donuts
Donuts
Ok , I know it´s a 4WD drive car, but I´m sure some donuts can be done. I´ve seen the Tiff Nedle video testing the RS4, and the guy only had fun while playing with the hand brake. Have some of you tried to do this? Is it possible to lock the rear wheels with the hand brake and have the front wheels doing the job/donuts for you
With a 993 Carrera 4 S it´s an easy job. You just have to lock the steering to one side while running and than use the hand brake to let the rear end brake loose, and as soon as the the rear tires slide a bit, you give full power with the steering lock , the car spins and makes several donuts in the same place, it´s great to see from outside and even better to feel inside
Haven´t you seen the way Tiff Nedle brake loose the rear tires? He´s using the hand brake to do so.
Maybe in the 4S Porsche it´s easier because you have more power on the rear wheels than on the front, so the the rear keeps spining all the time.
You can do a donut! I've done this several times. But don't try it in the dry. Way to much grip and will put some serious stress on everthing.
Find one MASSIVE car park and I mean REALLY big space because even in the wet the quattro gets some impressive grip and acceleration. The handbake method will work. I simply rolled along in 1st at about 10mph turned in very sharply and slipped the clutch. This had the RS taking on a seriouly fast and very wide four wheel broadside the first time on turning rapidly in the other direction she took on a classic tight donut but at speed! The second time I managed to get the donut from the get go. BE WARNED you really need a hell of a lot of space to do this. Best in snow or a really wet area to be kind to the drive train.
Users browsing this forum: Majestic-12 [Bot] and 72 guests
