Some MTM Chip questions...
2.7 V6 30v biturbo - 380 bhp
Lemon_S
Post by Lemon_S » Thu Jan 06, 2005 5:25 pm
Recently I bought an MTM 458HP Chip (yes.. only the chip) from ebay(German). When I received the chip, I discovered that this is just a regular EEPROM chip, not something that MTM normally shipped(EEPROM chip with a decoder on the back). The German guy told me that is an MTM chip for sure..... but I really don't believe it.
Does MTM really ship RS4 chip without adding decoder on the back or I simply got fooled?
Please adviced..... I can handle the truth......
Also... Is MTM 420HP the same as MTM 458HP chip?
sitas3
RE: Some MTM Chip questions...
Post by sitas3 » Thu Jan 06, 2005 5:36 pm
I don't know about the physical chip itself but the 458bhp code is written for better downpipes and freeflowing cats whereas the 420 is based on stock exhaust.
simple1
Post by simple1 » Thu Jan 06, 2005 7:02 pm
Think you will also find that there are different chips for each of the three ECU's which were used in RS4's.so you may find that even if it is the correct chip that it may not work in your particular ECU. I am sure there are better equiped people who frequent this forum who can advise you.
RS4_STEVO
Post by RS4_STEVO » Thu Jan 06, 2005 7:53 pm
I would never buy any of these chips or ECU's that are offered on Ebay! but that doesn't rule out that they copied the chip (duplicater!!!)
Taipan
Post by Taipan » Fri Jan 07, 2005 7:00 pm
EEEEKKKKK !!!!
MTM Chip on Ebay ? Mate, run away from that asap !
If you know a good mechanic in Taipei (and I have NO doubt there are), I'd recommend you place an order DIRECTLY to MTM for :
1. Full exhaust : sport catalyzers + intermediate/rear silencer
2. 458hp chip (which only works with the full exhaust).
and get your mechanic to install it.
If you have a doubt about the chip, you can fedex your ECU box to MTM and they'll do the right thing for you.
Eric
PS : don't go the cheap/shadow way on your RS4 engine, saving 2000 USD will cost you 15-20000 USD if you blow your engine.
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
Golich
Post by Golich » Fri Jan 07, 2005 8:08 pm
Taipan is right - :shock: You would have to be mad to to use a chip that you have no way of knowing what its parameters are set for. The 2.7 engine is a not simply a turn up the boost pressure type of deal. Get your money back or bin it.
Lemon_S
Post by Lemon_S » Fri Jan 07, 2005 8:45 pm
Thank you all for the answers
PhilT
RS246.com
Post by PhilT » Fri Jan 07, 2005 9:48 pm
And the rest... Try 50,000 USD. The engine alone ishalf of that!!
Users browsing this forum: No registered users and 110 guests
