LOBA RS4/S4 B5 8 pot brake calliper and 362mm disc Upgrade
2.7 V6 30v biturbo - 380 bhp
supersi
Post by supersi » Tue Oct 16, 2012 8:11 pm
LOBA RS4 S4 B5 8 pot Calliper and 362mm Front Brake disc upgrade kit
Kit comprises of :
A set of Black Brembo 8 pot Callipers inc bolts (colour of calliper can be changed to your choice at extra cost as well as decals)
LOBA bells and 362mm AP Racing rotors (either drilled or grooved no extra cost)
HEL braided steel brake lines
LOBA RS4 B7 Front Brake Disc Upgrade & 8 Pot Brembo Callipers
A pair of supplied brembo 8 pot callipers (black) and using AP Racing 48 Vane Directional rotors with a choice of either Grooved or Drilled.
The assembly uses “ Float in the Bell” Technology, float is limited to 0.2mm compared to 0.5-0.7mm float disc systems such as Alcon or less capable AP racing setups.
Custom rate developed bobbin springs allow design axial and radial float whilst maintaining OEM levels of noise.
Assembly's proven to demonstrate excellent heat management by design in testing due to axial flow of air from behind the bearing to the centre of the disc via 48 vanes and a 17mm air gap, provision is also made for front face cooling via recessed vents on the reverse bell face.
All components from rotors to washers are available separately this is truly a disc assembly for life, whole life cost is lower than OEM especially for tracked vehicles, Disc finishing is either radially drilled via CNC to avoid hotspots or curved grooved, rebuild and refinishing service facility available. Once the LOBA Upgrade is in place, simply replace the cast iron rotor when needed.
Design requirements was nominally 10-12 track laps at competitive driver speeds, surpassed in initial testing by professional drivers.
Optionally available with temperature sensing paint applied to rotors set from 430/560/610 degrees.
Disc Rotor is Supplied assembled
Rotor size is 362mm, thickness is 32mm, complete disc weight 8.7Kg
Brembo 8 pot callipers
Comes with braided steel brake lines
Your choice of Grooved or Drilled Rotors
Priced in pairs as a complete set-up (not including pads)
Once LOBA system is in place, simply replace the AP rotor when needed.
When used with performance pads and hi-temp brake fluid, you will have a proven and truly fantastic track and fast road set-up.
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
Paddski
Re: LOBA RS4/S4 B5 8 pot brake calliper and 362mm disc Upgra
Post by Paddski » Tue Oct 16, 2012 8:24 pm
Got any pics of red calipers and can you do a carbon fibre finish on the calipers?
paddy
RS6 Performace C7
Honda NSX 2017
Ford Licensed Shelby 1966 350GTH Replica......in build.....
Porsche Cayman GT4 Agate Grey...Wrapped Matte Blue, sold
RS4 B7, 2007, 20" HRE P40's + MRC mods
Bentley Continental GT Titan 600hp, sold
L200 Barbarian, sold
supersi
Post by supersi » Wed Oct 17, 2012 10:32 am
To show a few we colours done
Caillper guy does say could do a carbon finish
Users browsing this forum: No registered users and 19 guests
