Hi guys!
If there's anyone with VAG-COM and multifunction steering wheel (the one with volume and telephone controls on it) I am in need of the coding for the module - can be found in the "Soft. coding:" label.
(a screenshot of the VAG-COM window in function 03 - ABS Brakes would be perfect).
After removing the steering wheel (to replace a malfunctioning component) the ABS unit lost its coding... and right now my ESP and brake lights are on. They can probably fix this on Monday... but I wanted to drive the car during the weekend. I already have the login sequence, all I need is the coding.
Thanks to anyone that can help.
Boris
ABS coding needed!
Had the same problem a while back with same non response.......cmon 246 people
try http://forums.audiworld.com/s4/msgs/510314.phtml
Worked perfect for me......bit weird driving in circles to reset the esp
hope this helps for all future ABS/ESP problems.
And remember the airbag is very powerful so disconnect the battery and dont stand in its way when removing the steering wheel
Nik
Nik
