fixing an rs4 FDP gearbox
2.7 V6 30v biturbo - 380 bhp
dummi
Post by dummi » Thu Aug 16, 2007 6:07 pm
i'm planning to make the box useable and to do so i need to know what parts are different from the 2000 FDP box to the 2001 , i have ETOS from ebay but it only gives 2001-2 , i'm really stuck now on what exactly i need to change, as far as i know it is the syncro's for first and second gear and their hub, but i could be wrong, i need to know parts and part numbers required ... thanks
smurfbus
RE: fixing an rs4 FDP gearbox
Post by smurfbus » Fri Aug 17, 2007 6:23 am
I think they are all updated to the same parts
dodgydave
Post by dodgydave » Fri Aug 17, 2007 10:26 am
Hi,
FDP is FDP but FDP is the oldes box and therefor can be ugraded with the goodies of the newer boxes.
These are the manifacture dates:
FDP/FRQ from 11.00 to 04.01
FTU from 04.01 to 09.01
FZW/FZV from 01.02 (service Boxes with the 1/2 sync update)
Now I know that you need the 1/2nd sync hub/locking collar upgrade. I've also seen later boxes having a wider 1st gear but I can't find that confirmed in any audi docs. But the wider 1st exists!!
The complete 1/2 gear sync repair set is # 01E 398 270
I will see if I can find the wider 1st gear part numbers and will post if I do.
hope that helps,
Dave
Never enough...
dummi
Post by dummi » Fri Aug 17, 2007 12:43 pm
thanks Dave! for the 1/2 sync repair set
i didn't know about the wider first gear, i take it that was not actually a problem they just wanted to upgrade it from 3.5:1 'while they were in there' ?
thanks bud
smurfbus
Post by smurfbus » Fri Aug 17, 2007 1:51 pm
My etka7 does not know about # 01E 398 270. Do you know how much for the set?
I found these #:
01e311239l synchronizing hub 1st 2nd = 280eur
012311247H synchronizer ring 1st 2nd = 2*59eur
01E311257F first gear
01E311271B second gear
012311295F synchronizer ring 3 4 5 6 = 4*29eur
01E311301 synchronizing hub 3rd 4th = 217eur
dodgydave
Re: RE: fixing an rs4 FDP gearbox
Post by dodgydave » Fri Aug 17, 2007 2:41 pm
smurfbus wrote:My etka7 does not know about # 01E 398 270. Do you know how much for the set?
I found these #:
I use ETKA7 and I can find it!!! UYou need strip all spaces from the part number.
I only have euro pricing though. 182 euro + VAT
Never enough...
dodgydave
Post by dodgydave » Fri Aug 17, 2007 2:57 pm
dummi wrote:thanks Dave! for the 1/2 sync repair set
thanks bud
Not wider like longer in ratio !
Wider as in the actual gears are 10% wider to take more torque.
Never enough...
dummi
RE: Re: RE: fixing an rs4 FDP gearbox
Post by dummi » Fri Aug 17, 2007 3:46 pm
i need etka7! i haven't figured out how 8 works yet
oh! haha i see dave i need that then, that would be 01E311257F?
smurfbus are those all the parts that differ from 2000 to 2001-2? or are they they same part numbers as the old ones... i'm confused
smurfbus
Post by smurfbus » Fri Aug 17, 2007 4:08 pm
those are 2001 numbers but I'm pretty sure they are the same in newer ones too. Oh normally the gears themselves are fine so you only need the synchros and slider.
Dave: I tried without spaces too but i guess I should run the update but I dont want to risk a working etka7 by updating as it always stucks at vw update.
dummi
Re: RE: Re: RE: fixing an rs4 FDP gearbox
Post by dummi » Fri Aug 17, 2007 5:42 pm
smurfbus wrote:those are 2001 numbers but I'm pretty sure they are the same in newer ones too. Oh normally the gears themselves are fine so you only need the synchros and slider.
excellent
i pulled up rs4 2001-2002 on etka 8 and i saw something i didn't expect, the first gear ratio is 3.5:1 same as my a6 was, also part number is the same 01e311257f. more confusion haha
scottmandu
Re: fixing an rs4 FDP gearbox
Post by scottmandu » Thu Jan 12, 2012 4:23 am
Pretty much all 01E's had a 3.50 first gear ratio. The exception to the rule is the allroad and a tdi transmissions built after 2003, which had a 3.75 first gear ratio.
The wide first gears (26mm) were utilized in 1996 and later. The earlier 01E's has a 22mm first gear.
To update the 1-2 shift collar, you need the following pieces:
Qty1 01E311239L
Qty2 012311247H
The brass syncro rings in 3-6 gears are also updated to 012311295F.
These guys offer kits for the 01E.
http://www.advancedautomotion.com/advan ... l&x=0&y=0
RSKiwi
Post by RSKiwi » Thu Jan 12, 2012 4:32 am
Good info but possibly 5 years too late??? :beerchug:
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
scottmandu
Post by scottmandu » Mon Feb 06, 2012 10:38 pm
Better late than never!
Users browsing this forum: No registered users and 72 guests
