Clutch time and a new flywheel
2.7 V6 30v biturbo - 380 bhp
tanoga
Post by tanoga » Mon Apr 19, 2004 9:23 pm
sitas3 wrote:whilst having my turbos replaced, I've also taken the opportunity to get a Tanoga flywheel and RS4 clutch fitted to my S4.
Today, after nearly 4 weeks, I finally get the car back and all seems to be well currently!
I was told there would be some increased noise with the new flywheel which there is at lower revs- especially third gear around 1500 revs (sounds like a tractor!) - some questions for those who have had the lightened flywheel mod: have you noticed the same? also, why is the noise more apparent in third gear?? Joshie/Prawn I think you've had this mod on your previous S4's..
I assume it is the same with the RS4's?
Simon
You can mitigate the noise by changing up to 3rd gear at a higher road speed then you had previously been used to. Also try to avoid cruising in 3rd(or any higher) gear at low road speeds.
Mog wrote:The noise problem concerns me as I'm having a lightened flywheel this week although not a Tanoga.......how can a flywheel make a noise!!!!!
Mog :nogarors4:
Clive
A lightweight flywheel does NOT make a noise. The standard dual mass Audi flywheel has springs inside it that muffle out the engine/gearbox noise so you cannot hear what is already there, if that makes any sense.
quovadis
spec clutch
Post by quovadis » Tue Apr 20, 2004 2:17 am
I'm just about to install a spec clutch and flywheel...i will let you know what happens.
Joshie
Post by Joshie » Tue Apr 20, 2004 4:47 am
The noise was only apparent at very low revs and was a kind of metallic russle. If anything I made sure that I wasn't pulling from 1-1.5K RPM in any gear and once my driving style had changed I never noticed it again.
For me the increased performace and flexibility was well worth the trade off
Bushy
Post by Bushy » Tue Apr 20, 2004 6:26 am
Cant wait to find out :(
Can't beat a bit of boost!
sitas3
Post by sitas3 » Tue Apr 20, 2004 8:19 am
thanks for your response Karl. ok change of driving style it is then. at least that way, the turbos will be spooled ready for action!
Jon
Post by Jon » Tue Apr 20, 2004 9:57 pm
The rs4 has a "damped" flywheel, so when you put an undamped, or single mass flywheel in, you reduce the weight but the trade off is extra noise from the vibration passing through. Spins up a lot quicker through the revs though.
