Just spoke to the seller about the above, has had MTM 460 & Miltek system and quickshift.
FASH
new brakes & belt done at 77k longlife service.
Can anyone give me reason not to be interested about this car ??
Standard brakes with 460bhp ??
Longevity of the engine ??
No tracker fitted yet !!
It's advertised in autotrader with a dealer but I spoke to the owner who is a friend of the dealer's. London area.
many thanks
Steve
Avus 84k @ £26k
It'll be the cheapest RHD RS4 in the country and you'll save £4k on the MTM conversion
Go and drive it and pay the usual attention to smoke and noises, also check whether someone like Listers will warranty it for you for piece of mind.
I'm sure there's a few modded RS4's with this sort of milage knocking around who'll comment.
Brakes will suffice on the road, I've not had any problems with my standard set up yet.
Ben
Ben
Go for it, nothing wrong with high mileage Audis, basically a good engine and the car is great as long as it has been looked after that is fine
You should be able to tell if it has had TLC by seeing it
As Ben says the standard brakes are ok for standard driving, I guess!!!! It is only when you start spirited driving something better is required
Can't beat a bit of boost!
Why not buy mine instead? It's done 26000 miles less and is only a few grand more
http://www.rs246.com/index.php?name=PNp ... ic&t=44782
RobK
www.nogaro.org
www.nogaro.org
Users browsing this forum: Google Adsense [Bot] and 98 guests
