Nasty misfire
2.7 V6 30v biturbo - 380 bhp
RobK
Nasty misfire
Post by RobK » Mon Feb 09, 2004 9:32 am
My car's misfiring horribly when applying full throttle. The whole car starts shuddering and the check engine light flashes [img]images/graemlins/frown.gif[/img]
The error log reports misfires on 3 cylinders. Anyone have any idea what the likely cause is? I don't really want to spend a load on new spark plugs if it's not going to help.
I did have a similar thing happen a while ago which turned out to be something to do with the lambda sensors in the exhaust. Would that cause a misfire?
Jon
Re: Nasty misfire
Post by Jon » Mon Feb 09, 2004 10:32 am
I had a missfire on cylinder 3 probably caused by 100 cell cats. Audi binned the car instead of fixing it
sitas3
Re: Nasty misfire
Post by sitas3 » Mon Feb 09, 2004 10:36 am
Rob, could this be a dodgy coil pack?
M3 CSL - Silver Grey, a few options.
PhilT
RS246.com
Re: Nasty misfire
Post by PhilT » Mon Feb 09, 2004 10:38 am
What gear are you in when this happens? Might be worth getting the plugs and injectors checked.
RobK
Re: Nasty misfire
Post by RobK » Mon Feb 09, 2004 10:51 am
It does it in any gear, but it happens most in 2nd and 3rd cos that's when I boot it most [img]images/graemlins/laugh.gif[/img]
Nige_RS4
Re: Nasty misfire
Post by Nige_RS4 » Mon Feb 09, 2004 2:06 pm
Have you tried dropping back down to the std ECU programme(IIRC you're Revo - do you have SPS3?) - to see if that makes a difference ?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
RobK
Re: Nasty misfire
Post by RobK » Mon Feb 09, 2004 2:22 pm
It was at Dialynx last week and they turned the boost down about 10% from what it was, and the misfire is worse if anything.
Bushy
Re: Nasty misfire
Post by Bushy » Tue Feb 10, 2004 7:32 am
been having similar problems for the past 3 weeks, although more at lower revs, changed all 6 coil packs and all 6 spark plugs and MAF, all made a slight improvement but not really sorted it out
Bloody nightmare
Totally pissed off with Audi over the whole thing
AmD have checked the lambda's seem OK, next thing is fuel pump is making a high pitched noise so awaiting a new one to arrive as they are on back order
Changing the injectors isnt too cheap, really getting me dsown now so will be glad to see what you find out mate
Bushy
Can't beat a bit of boost!
dog
Re: Nasty misfire
Post by dog » Tue Feb 10, 2004 11:32 am
Funny, I had misfireing 2 weeks ago, not as excessive as your s though.
Filling up with BP ultimate instead of the Optimax seem to fix the problem
RobK
Post by RobK » Mon Mar 22, 2004 11:29 am
Well, Mitchell from Revo came over yesterday and it's now all sorted :D
The main problem was a bad MAF which was reading very low. Fitted a new sensor, courtesy of Bushy (cheers mate!) and Mitch made some tweaks to the program, and it's all super smooth and speedy again!
Bushy
Post by Bushy » Mon Mar 22, 2004 11:53 am
Pleasure mate, glad I could help
Bushy
Users browsing this forum: No registered users and 61 guests
