Brakes Issue.....
2.7 V6 30v biturbo - 380 bhp
SpeedJunky
Brakes Issue.....
Post by SpeedJunky » Fri Jan 28, 2011 9:22 pm
I have K-Sport 8-Pot fronts on my RS4 B5 and for many months now they have felt and stopped like they could stop a freight train....
Anyway, recently I have an issue, where I percieve that there is significant travel of the brake pedal when I brake sometimes, maybe I am going mad, but I think when I stamp on the brakes they respond brilliantly with a sharp bite and the front dips big time, BUT if I press the pedal slowly it feels like there is a huge amount of travel....and somtimes when I get real low on the pedal a major grind/vibration comes back through the pedal....not all the time though...
Any Ideas?
stunew
Post by stunew » Tue Feb 01, 2011 4:34 pm
This sounds very much like a broken ABS reluctor ring on the driveshaft, mine is doing just what you say and its broken a rear one. Unable to pick it up on Vagcom either.
SpeedJunky
Post by SpeedJunky » Tue Feb 01, 2011 9:29 pm
Thanks for answering, I have come to the same conclusion by researching on the net and looking up my symptoms. I will have a look this weekend to check it out. I was just about to post but you beat me to it!! :)
Thanks!!!
Misano Red - 470bhp
3' downpipes, Miltek, KSport 8pot front brakes, RS6 Callipers/RS4 B7 discs rear, ITG Filter
SpeedJunky
Post by SpeedJunky » Tue Feb 01, 2011 10:05 pm
I have read somewhere that Vagcom specifically does not pick up this fault.
Misano Red - 470bhp
stunew
Post by stunew » Tue Feb 01, 2011 10:39 pm
No diagnostic equipment picks it up, I have tried 3 different machines including a VAG one.
Pop off the wheel and remove the big bolt in the centre of the hub/disc, usually a 14mm allen key. Then you can push the driveshaft out far enough to be able to see the ABS ring from the rear of the hub where the driveshaft fits in. Turn the brake disc slowly while looking at the ring for a crack. Generally its the rear ones that go, i got one on ebay for under a tenner.
SpeedJunky
Post by SpeedJunky » Tue Feb 01, 2011 10:57 pm
Thanks! I will check the rear ones first then! :)
Do you need to heat up the new one to pop it back into place? I am not sure how they are fixed into place on Audi's you see. :)
Misano Red - 470bhp
stunew
Post by stunew » Wed Feb 02, 2011 7:43 am
Yes, you will need to remove the driveshaft, clean up the ring location as best you can then heat the new ring and gently tap it into place.
SpeedJunky
Post by SpeedJunky » Wed Feb 02, 2011 10:13 am
Ok thanks again, you have been most helpful!
I am looking forward to the weekend now, I swore my days of p!$$ing about with cold cars on a cold day with numb fingers on the roadside were over.... :)
Misano Red - 470bhp
Users browsing this forum: No registered users and 60 guests
