RS4 B5 brake rotors replacement. Help!!!!
2.7 V6 30v biturbo - 380 bhp
rs4crazy
Post by rs4crazy » Wed Nov 24, 2010 4:06 am
:cry: Can anybody help me where I find out drilled rotors for my car? I have been searching the web like crazy and I only find big brake kits that are unaffordable for a brazilian car. I would like to only change the rotors not getting a complete new brake.
boxerdogted
RE: RS4 B5 brake rotors replacement. Help!!!!
Post by boxerdogted » Wed Nov 24, 2010 7:56 pm
Special order from Quattro GmbH, you will need a chassis number from a car that had them fitted when new or they wont supply you.
The price will frighten you.
2001 RS4 Misano Red
rs4crazy
Post by rs4crazy » Thu Nov 25, 2010 2:09 am
Thanks you. I had already figure that out. But what about other rotor brakes manufacturer such as EBC, Wilwood or even Brembo or Movit? Wouldn´t them built such parts? What you guys do in Europe when is to replace a rotor?
neckarsulm
Post by neckarsulm » Thu Nov 25, 2010 9:27 am
Why not fit B7 RS4 discs?
Not sure if they are compatible with the standard caliper though
Savage
Post by Savage » Thu Nov 25, 2010 12:02 pm
Mr Crazy,
EBC do specific Discs (sorry Rotors) for the B5 RS4 Part Number D1148 Front and D1149 on the rear. You have to ring them to get prices though.
Sav
Sav
All too often, the light at the end of the tunnel, is the headlamp on the on coming train of dissapointment!
rs4crazy
Post by rs4crazy » Thu Nov 25, 2010 7:06 pm
I was looking for a drilled discs but it is getting to hard to find one. Everything I looked has to go through replacing the calipers and pads as well. I will try the EBC discs.
Thanks,
Ed
RS4KID
Post by RS4KID » Fri Dec 03, 2010 1:38 pm
i hope you dont mind me asking this here ..........I got RS4 B7 Rears cross drilled but when i wanted to install i found out that my b5 comes with the sensors and the rs4 pads dont have the wires...so what do I do?
boxerdogted
Post by boxerdogted » Sun Dec 05, 2010 5:30 pm
Cut the plug and lead from old pads, solder and heatshrink the two wires together and plug back in.
Just remember you wont get a warning when you rear pads are low.
HTH
2001 RS4 Misano Red
RS4KID
Post by RS4KID » Mon Dec 06, 2010 6:07 am
boxerdogted wrote:Cut the plug and lead from old pads, solder and heatshrink the two wires together and plug back in.
HTH
Awesome...Many thanks
prosty
Post by prosty » Mon Dec 06, 2010 6:26 pm
EBC only lists these discs but they have never manufactured any, at least not as of late. I've tried contacting EBC in Europe about this and they say excatly what I stated here. They have a P/N but it is not active, trust me on this.
The only one that can sell rear front and rear discs beside stock are DBA and a swedish tuner (fastone.se) and also tar-ox, but tar-ox are really slow in correspondance, Ì've got a reply that they can sell them to me, but no reply since that when I asked about shipping and payment info (contacted tar-ox italy directly)
I guess it might be possible that some other tuner sells these discs too, fastone has manufactured an own floating hub with interchangable rings.
So the first swap is about the same price as OEM, but the ring change is about half the price.
prosty
Post by prosty » Mon Dec 06, 2010 6:28 pm
There is a dude on ebay.de named ur1980 that can supply these drilled b5 discs, they are NOT cheap however, you don't need to supply your vin code for this deal though.
This was with calipers, he didn't have an auction with just these discs at the moment
http://cgi.ebay.de/Original-Audi-RS4-Br ... 588abee24b
mattykerby01
Post by mattykerby01 » Sun Dec 12, 2010 10:08 am
I have the B7 setup on the front of mine and just brought a pair of VW Phaeton V12 discs (1/3 of the price), need to just swap the 'bells' over on exisiting discs. The discs are just plain but i just about to machine 8 evenly spacers grooves in each side - cross drilled discs crack !
RS4ever
Re: RS4 B5 brake rotors replacement. Help!!!!
Post by RS4ever » Wed Feb 15, 2012 5:03 pm
I have some drilled quattro gmbh front disks. I have the calipers too. PM me if you are interested.
