just Clocked 100k and i need to do a full service, please help with reccomendations
Car is Running 420bhp
Oil Filter
What Oil should i use ?????
Air Filter
Pollen Filter
Spark Plugs (Rs2???)
Fuel Filter
Cam Belt
Thermostat
Change coolant
Change Brake Fluid
IF you can think of anything else that i should do let me know please,
100k Service Please Help ....!
- 1st Gear
RE: 100k Service Please Help ....!
If your changing cambelt , change the tensioners and waterpump aswell
Re: RE: 100k Service Please Help ....!
rollers and bolts etc..ess4avant wrote:If your changing cambelt , change the tensioners and waterpump aswell
RE: Re: RE: 100k Service Please Help ....!
Don't forget the thermostat!!! Also you could/should think about renewing some of the bushes, replacing the front arms (a common failure on 100k+ Audis). If the exhaust/cats are original give them a check over too.
New cams ?
- 1st Gear
the front arms are the wishbones ??
