coolant temp gauge
chiefmechanic
coolant temp gauge
My coolant temp gauge hardly ever gets to 90. Will normally sit half way between 60 and 90. With the aircon switched off it still wont get to 90 while driving along. The only time it gets to 90 is if i leave it ticking over with the air con switched off. Is this normal. Brian
- Virdee Autos
- Trader (Expired)
RE: coolant temp gauge
No, not normal
Sounds like the thermostat is gone
Virdee Autos ~ 07950-526592
neckarsulm
...which means a cambelt off job unless your name is Uri Geller
- Attachments
- mindforce_1.jpg (8.06 KiB) Viewed 1782 times
- Virdee Autos
- Trader (Expired)
Underneath the pipe between the airbox and MAF
chiefmechanic
coolant temp gauge
Just found out that the viscous fan is siezed. Need to change that before looking at something else. Brian
i had the same problem, Grizz did my cambelt last week and now it hits 90 after 5 or so minutes.
Also noticed the oil temp goes a bit higher aswell.
Users browsing this forum: No registered users and 104 guests
