Can I still use my RS4's intake manifold if i change to 2.8.
2.7 V6 30v biturbo - 380 bhp
tigasTT
Post by tigasTT » Wed Dec 02, 2009 9:30 am
Can I still use my RS4's intake manifold if i change to 2.8 5valve heads? TIA
musty1
RE: Can I still use my RS4
Post by musty1 » Wed Dec 02, 2009 9:43 am
yes you can use the inlet manifold on 2.4 and 2.8
1.9TDI A6 are sh*t wrong forum
tigasTT
Post by tigasTT » Wed Dec 02, 2009 5:34 pm
hi Musty thanks for the info.
so does this mean i can use the heads from a 2.8 in my ASJ(RS4 engine) and not change anything else? TIA
musty1
Re: RE: Can I still use my RS4
Post by musty1 » Wed Dec 02, 2009 8:23 pm
tigasTT wrote:hi Musty thanks for the info.
Do you have the secondry air system on your car? if so you will have to take out the ball bearing out of the hole on the 2.4 or 2.8 as they dont run the secondry air system but aprt form that everything else should be the same
p.s change the exhuast valves to sodium filled ones
tigasTT
RE: Re: RE: Can I still use my RS4
Post by tigasTT » Thu Dec 03, 2009 12:57 am
Musty, I have an ASJ engine...I dont know if I have a secondary air system. Thanks for all the help! Cheers! :)
musty1
Post by musty1 » Thu Dec 03, 2009 9:32 am
all RS4's come with it unless you have removed it will be there
Users browsing this forum: Google [Bot] and 104 guests
