i'm not refering to your assistance in my wheel quest!N11LS_J wrote:I'm looking on your behalf!
Sweet, is that just the rear? Knowing that it sounds like I could run a 19x10 +24mm offset pretty safely (Not that I want to but if that's possible I know for a fact a 19x10.5 +20mm offset would be perfect) Are you at risk of rubbing your tires on the fender lip? Would rolling the fenders fix that?N11LS_J wrote:Not sure how low exactly, can measure for you if required, since fitting the 10 x 19s, i have had to raise the car slightly, now sitting just above the tyres, Bilsteins set on setting 6 all round, no problems with rubbing, catching etc. Camber i'm unsure about mate, haven't really tinkered with it much so should be near enough OEM, i'm having the geometry setup at the end of the month, so will know more then.
Admitting you have a problem is te first step... well done!
Saying that, i'm not sure I want to be 'clean', I love being a wheel whore!
