Hello, hope you guys might be able to advise on the following -
Cars been running pretty rough recently sounding like a diesel, engine management light keeps coming on and staying on, so i've had it in for the following work done -
Timing belt service which was about due, parts replaced -
timing belt
tension roller
relay roller
tensioning damper
water pump
Also had the following replaced -
2 timing chains
2 camshaft adjuster units
2 rocker cover gaskets
Plus major service plugs, oil, filters etc
However the engine management light is still on and the following faults have been found on vagcom -
16730 - Camshaft position censor (G163): Implausible signal
p0346 - 35-00 - -
16684 - Random/multiple cylinder misfire detected
p0300 - 35-00 - -
16688 - Cylinder 4: Misfire detected
p0304 - 35-00 - -
16690 - Cylinder 6: Misfire detected
p0306 - 35-00 - -
16689 - Cylinder 5: Misfire detected
p0305 - 35-00 - -
Cars got 110K on the clock
Any advice much appreciated
HELP - i think the end is near!!!
2000 - Avus RS4
- mikeyquattro
- Top Gear
Re: HELP - i think the end is near!!!
I trust you inspected the cam lobes for wear when the rocker covers were off??Marlon wrote:Hello, hope you guys might be able to advise on the following -
timing belt
tension roller
relay roller
tensioning damper
water pump
2 timing chains
p0346 - 35-00 - -
p0300 - 35-00 - -
p0304 - 35-00 - -
p0306 - 35-00 - -
p0305 - 35-00 - -
- mikeyquattro
- Top Gear
RE: Re: HELP - i think the end is near!!!
I bet the Cam timing is out ... Who did the job... I would not start it any more ..Get it looked at
Unit 20
0151 3366888
0151 3366888
- mikeyquattro
- Top Gear
