Fault codes...
2.7 V6 30v biturbo - 380 bhp
rhunter203
Fault codes...
Post by rhunter203 » Fri Aug 21, 2009 9:35 am
Ha s anyone had the following fault codes:
P0300 Random Multiple cylinder:
Misfire detected
P0304 Cylinder 4:Misfire Detected
Rob
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
rtd
Re: Fault codes...
Post by rtd » Fri Aug 21, 2009 9:53 am
rhunter203 wrote:Ha s anyone had the following fault codes:
Misfire detected
Rob
check this link rob;
http://wiki.ross-tech.com/index.php/16684/P0300/000768
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
TopBear
RE: Re: Fault codes...
Post by TopBear » Fri Aug 21, 2009 12:54 pm
Yep, I had that regularly, just before my cams needed replacing. :( It could be a multitude of things causing this though. Duff coil pack(s), amplifiers, injectors, MAF.........
You should be seeing more than 1 cylinder misfire (in your case cyclinder 4) for a 'Random\Multiple' DTC code though
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Nige_RS4
Post by Nige_RS4 » Fri Aug 21, 2009 1:56 pm
I saw that on my RS - plugs needed tightening (seems to be quite a common thing!)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
rhunter203
Post by rhunter203 » Fri Aug 21, 2009 2:34 pm
Oh dear lets hope its one of the cheaper options...
3.6 0-60 12.04 1/4M
TopBear
Post by TopBear » Fri Aug 21, 2009 4:46 pm
If you measure and log blocks 15 and 16, you can 'watch' which cylinders are misfiring, and at what revs they misfire, to help you narrow down the focus a bit.
rhunter203
Re: RE: Re: Fault codes...
Post by rhunter203 » Mon Aug 24, 2009 4:34 pm
TopBear wrote:If you measure and log blocks 15 and 16, you can 'watch' which cylinders are misfiring, and at what revs they misfire, to help you narrow down the focus a bit.
Thanks. The main problem I have is the car has only misfired once!
3.6 0-60 12.04 1/4M
TopBear
Post by TopBear » Mon Aug 24, 2009 4:50 pm
I take that to mean it's only logged misfires once as DTC's, and you've cleared them and they never came back?
Perhaps poor quality fuel is to blame then?
rhunter203
RE: Re: RE: Re: Fault codes...
Post by rhunter203 » Mon Aug 24, 2009 5:20 pm
The misfire happened after I gave the car full beans from cold – I know this is a no no but I pulled out to late. The car stuttered
then the engine management light came on, I immediately stopped the car and turned off the engine, I left it for 5 mins, started
up and drove very gingerly back home – the light has never come back on nor has the car misfired again.
I haven't cleared the codes yet - booked into MRC for Thursday and thought it best if I leave well alone!
3.6 0-60 12.04 1/4M
Users browsing this forum: No registered users and 89 guests
