I guess this can't be normal, has anyone else come across it?
The only reason I noticed was because water was sitting there from testing the seals on my injectors to which I have now fitted new o-rings and I could see and hear air loss.
It's only slight, do I need to replace the manifold gaskets?
Both sides do it...
Leak from inlet manifold gaskets while pressure testing...
neckarsulm
I had the same thing on my RS when pressure tested,big leak on injector seals which are cheap to get and also suspected the inlet manifold gaskets so changed them too,about £3.50 to £4 each from tps,they are pressed metal gaskets.
Good luck
Cheers "Bingo"
Good luck
Cheers "Bingo"
2002 Noggy RS4,AP 6 pots,Revo,H&R big arb's,milltek.
neckarsulm
Thanks Bingo.
Did you do it yourself?
If so how much more work once the fuel rail removed is it?
Are all the bolts easy to get to.
Did you replace the throttle body gasket too or did you not touch it?
PS Car feels quicker with just injector seals done (and ambient air temp is much higher than when I last drove it)
Yes did them myself,easy job once the fuel rail is out of the way but Idid remove the throttle body and pipes from the intercoolers and replaced all the o'ring seals and used "loctite" high temp silicon sealant on the i/c and throttle body seals,put the manifold gaskets on dry without sealant.
All will become clear when you start if you are of a mechanical nature and you might also find some bad vacuum pipes etc at the back of the engine once you get it apart."Bolts" are easy to get to use a 5mm allen key/bit to undo manifold cap head screws and when its off inspect how clean your inlet valves are but try not to drop anything into the ports.
Cheers "Bingo"
Cheers "Bingo"
neckarsulm
Excellent, thank you
This forum's been a bit short on good advice recently
neckarsulm
Good ideaWhilst you are at it, good idea to do the after-run pump and spider hose, both ready to fail and easy to do when you've got the manifold off.
