FMIC - Do I really need to live with no AC fan then?
2.7 V6 30v biturbo - 380 bhp
Sql_RS4
Post by Sql_RS4 » Fri May 22, 2009 12:52 pm
I would like to replace my SMICs with an FMIC - especialy now that one is leaking some oil.
But I would like to know what can be done to keep the AC fan - I would not like to have problems with AC in traffic.
Also how about oil cooler?
Thanks in advance.
HGH
RE: FMIC - Do I really need to live with no AC fan then?
Post by HGH » Fri May 22, 2009 10:24 pm
SMIC's can't leake oil, because there is only going air in and out.
The oil comes from the turbo's i guess, and it is no problem, when its a little bit of oil
Clean the SMIC's and lower hoses, 2 or 3 times a year.
Sql_RS4
Post by Sql_RS4 » Sat May 23, 2009 12:12 am
I also found a little bit of oil in my Y-Pipe and my friend from US who is an S4 Maniac said that it must be something totally wrong because there should be absolutely no oil showing in Y-Pipe - but I think I have read somewhere that it is normal with our engines. Isn't it?
Oh and BTW - it turned out to be messed up clip for oil cooler hose that had a leak.
Blue_Thunder
Post by Blue_Thunder » Sat May 23, 2009 12:54 pm
Oil in the Y-pipe is nothing to worry about.
jimbo1234567
Post by jimbo1234567 » Sun May 24, 2009 8:02 pm
you cant do a fmic conversion without losing the ac fan, doesnt really matter unless you are sitting in a que of traffic in 40 oC heat in somewhere like spain,turkey or greece etc,..
