Another happy MRC customer
After nearly a year of happy RS4 ownership and the Dealer warranty rapidly ending, I booked my car in with MRC for a health check, plugs and fuel filter change. Even though my booking was made at short notice, they happily made time and workshop space to accommodate me.
Firstly a check with VAG-COM, apart from a misfire on cylinder one the only other issue was the timing, out 10 degrees on bank one and 3 degrees on the other - more on this later. Mine like many other RS4's still had the original MAF and fuel filter installed, both dated April 2001! Whilst the plugs were being changed (another item that looked liked it had not been changed by the Dealers at the last service!!!) MRC suggested removing the Cam covers to see for signs of wear.
Once the covers were removed, evidence of the dreaded signs of Cam wear on most lobe tips and considerable wear/play in the Cam tensioners, nice! The VAG-COM reported engine timings could be due to the wear/play in the tensioners or more likely the dealer (who did the Cam belt) not using the correct tool! Out on the road once all back together with Doug, the car’s completely different, power delivery is considerably smoother and noticeably more grunt up the rev range – fantastic, just like it should of been when I bought it!
All I need to do now is get Audi to pay for a sticking/wore clutch and the necessary Cam replacement work!! (I can give it a go anyway)
Enough of my ramblings, I thought I would put pen to paper to say that I have had many cars modified during my years and the staff at MRC are among the best I seen. Their attention to detail, technical knowledge and willingness to help and explain all aspects of the work is exemplary.
I know that for any future work (the new 3â€
- rhunter203
RE: Another happy MRC customer
Sounds about right to me!! My car had the exact same problem as yours plus had full stealer history!!
Whereabouts in Surrey are you??
Rob
Rob
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
3.6 0-60 12.04 1/4M
- rhunter203
neckarsulm
lemonpuff, hope you don't mind me posting your original thread when you were considering buying the car in order to add some context.
http://www.rs246.com/index.php?name=PNp ... highlight=
