Short shifter - any real issues?
2.7 V6 30v biturbo - 380 bhp
Sql_RS4
Post by Sql_RS4 » Sat May 16, 2009 10:51 am
Since day one of owning my RS4 I was not really satisfied with the way OEM shifter shifts and wanted to install a short shifter.
But I've read and heard from several sources how bad that is for your gearbox, synchros etc.
So the question is - I know a lot of you use either Tanoga, JHM or other shifters - what are your experiences? Any noticeable problems with your box after you installed it?
Thanks in advance!
rhunter203
RE: Short shifter - any real issues?
Post by rhunter203 » Sat May 16, 2009 3:15 pm
ESP shortshifter – no problems so far.
You can buy an OEM SS therefore I wouldn't think there would be any issues.
Rob
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
rtd
Post by rtd » Sat May 16, 2009 4:01 pm
rob i think the SS's which were fitted by dealers were Tanoga's according to Doug.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
bastos
Post by bastos » Sat May 16, 2009 8:23 pm
i have the home made short shifter for 7months now...
i dont think there would be any problems...
it feels great! :thumbs:
volts
dont be hating.....
Jules
Post by Jules » Sat May 16, 2009 10:48 pm
I have the tanoga,and i've had no issue's at all and i find it a smooth gear change
Drive low,park lower
frazered
Post by frazered » Sun May 17, 2009 3:58 pm
ESP one is great vfm - recommend getting the weighted knob to ensure it feels as smooth as possible
any SS will make it feel a bit notchier - apart from maybe the diy mod to the existing shifter
lengster1
Post by lengster1 » Sun May 17, 2009 9:44 pm
It doesnt do your box any harm,but what it will do is amplify the notchy change,theyre very fiddly to adjust and get aligned perfectly though
N11LS_J
Post by N11LS_J » Wed May 27, 2009 10:26 pm
I would like to know the above too...
For those who are running the ESP SS, how long have you had it? and have there been any issues/glitches etc with regards to gear changes or anything
I have one sitting in garage, but not sure if this is the route to go, as i've had some varied feedback
thanking you in advance for your input
Nils
rtd
Re: RE: Short shifter - any real issues?
Post by rtd » Thu May 28, 2009 10:23 am
N11LS_J wrote:I would like to know the above too...
Nils
as long as you don't fit the incorrect one like me then it will be fine!
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
rhunter203
RE: Re: RE: Short shifter - any real issues?
Post by rhunter203 » Thu May 28, 2009 10:57 am
I've had an ESP SS for around 4 months (middle setting) and everything seems fine at the moment!
3.6 0-60 12.04 1/4M
rtd
Re: RE: Re: RE: Short shifter - any real issues?
Post by rtd » Thu May 28, 2009 11:10 am
rhunter203 wrote:I've had an ESP SS for around 4 months (middle setting) and everything seems fine at the moment!
as above i think if its fitted correctly then there is no problems. however, if you have a gearbox with wearing synchros then the SS may accentuate the wear.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
rhunter203
RE: Re: RE: Re: RE: Short shifter - any real issues?
Post by rhunter203 » Thu May 28, 2009 12:25 pm
I've recently chatted to a friend of mine (top mechanic) who said, if the SS is fitted incorrectly then you'll screw up the synchros....
3.6 0-60 12.04 1/4M
rsmonkey918
Post by rsmonkey918 » Thu May 28, 2009 5:45 pm
I've got what I believe is a Tanoga SS fitted before I bought with a ESP stainless gearknob and the shift quality is sublime- have a ESP transmission stabiliser too- no driveline shunt- everything feels really tight, positive and well sorted. Sometimes have a problem with reverse- not all the time but I find for some really odd reason that if I slide it into 5th and then out straight into reverse its as smooth as silk- don't know why- it was suggested by someone I spoke to a while ago and it works every time reverse is a bit recalcitrant. I never force it, if it doesn't go in after engaging/disengaging the clutch a couple of times, 5th it is.
Incidentally Liam at ESP was offering the gearknob/driveline stabiliser at a discount when he first started selling them- might be worth asking about if you were thinking about a combo of SS/knob/DS- he's a top bloke.
Regards
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
