Are the Suspension arms on a B5 RS4 the same as on B5 A4?
Are the suspension arms the same across the B5 range, or are RS4 suspension arms RS4 specific? Thanks
RE: Are the Suspension arms on a B5 RS4 the same as on B5 A4
I'm sure I've read somewhere before that they're the same across the B5 (A4 \ Passat range)
The ball joints are not the same size on the lower arms. I think the front lower is rs4 specific to it.
Unit 20
0151 3366888
0151 3366888
B5 RS4 lower arm seems to be the same ball joint as the B6 A4
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
Generally pre facelift cars have different ball joints on the lower arm to the facelift however the change over was actually with a chassis code update so there is an overlap. The front lower arms are not RS4 specific.
Lucas ,
The front lower arm on a B5 RS4 PT NO 4B3 407 151C Is specific to the rs4 in the B5 platform The part is listed for use on other platforms as well.
It is listed for A8 , A6 & S6 But no other a4 or s4
Unit 20
0151 3366888
0151 3366888
