Misfire cylinder 4 ???
- mattykerby01
Hi,
Have the following fault codes when driving the car hard - can anyone shed any light for me?
Car has just been serviced with new plugs.
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
Coil packs maybe? Where is cylinder 4?
Matt
P0300 - 35-00 - -
P0304 - 35-00 - -
Matt
How did you get those codes, i.e. have you got VAG-COM?
You could try resetting the DTC codes, and then measuring the blocks 14+15 to see at what revs the misfires occur.....alternatively give MRC a call, and ask Doug or Minhea what can cause this, however from memory it could be either of the following......
a) Coil pack
b) Spark plug
c) Defective Injector
d) Crack in cyclinder head
e) Worn camshaft lobe\follower
Mines was option e
a) Coil pack
b) Spark plug
Mines was option e
- mattykerby01
Re: Misfire cylinder 4 ???
Mattmattykerby01 wrote: Car has just been serviced with new plugs.
Although my car appeared to be running ok, when getting a MRC re-map they did a health check and found a random missfire. It just turned out to be loose plugs on both centre cylinders. A common fault according to Doug, by dealers who don't tighten them properly. Where did you get the car serviced? It may be just that simple!!!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
RE: Re: Misfire cylinder 4 ???
Matt ,
P0300 - 35-00 - -
P0304 - 35-00 - -
I've had these on several cars when the MAF is on it's was out .
P0300 - 35-00 - -
P0304 - 35-00 - -
Unit 20
0151 3366888
0151 3366888
I had exactly the set of faults (on cylinder 6 though) .... cured by Doug (of course). Great expense...he tightened the spark plugs!
My suggestion is to go round all 6 plugs and re-tighten them, clear the fault codes and then drive the car for a while and re-test with Vag-com.
Paul
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin
If you dont "do it now" you never will.
Huge Grin
this is spooky.....
Doug had to retighten mine last week whilst he was going a few other bits and pieces for me....
2001 RS4 Avant - thats been touched by the MRC magic wand.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008
"spooky"? Sounds like Audi has fvcked up again!!!
Dave.
White MK2 Golf.. Slightly modified
EXHAUST CAM IS DAMAGED.
Re: RE: Re: Misfire cylinder 4 ???
thats a really helpful comment - NOT.dr.sah wrote:EXHAUST CAM IS DAMAGED.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
RE: Re: RE: Re: Misfire cylinder 4 ???
I'm guessing that sah has recently had cam issues and he's seen this vag code from this here thread and thinks it's the same.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
Users browsing this forum: No registered users and 88 guests
