Weird Shutter at 3-4k rpm when floored
2.7 V6 30v biturbo - 380 bhp
Sql_RS4
Post by Sql_RS4 » Thu Apr 23, 2009 3:24 pm
Very recently my car has developed a VIOLENT shutter under high load over as near as makes no difference 4k rpm. In all other throttle positions the car runs fine no matter the rpm. MAF says 270g/s according to the vag. The cylinder voltages are all over the map from 9 to 12 or 17 i dont remember. Any ideas what the problem could be?
No warning lights or any other symptoms. Wish i could describe the feel of the drive better. The run starts fine then over 4k when the boost is at the max it gets ugly. It is not subtle it is not hard to notice it is an in your face violent non regular vibration and it last until you take your foot off the gas. Car also feels noticeably slower, like it was in limp mode.
Any ideas guys?
Nige_RS4
RE: Weird Shutter at 3-4k rpm when floored
Post by Nige_RS4 » Thu Apr 23, 2009 3:29 pm
Maybe an EGT probe down or your spark plugs need changing? Do you get any errors with vag-com i.e. mis-fires?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Sql_RS4
Post by Sql_RS4 » Fri Apr 24, 2009 12:16 am
No errors but I came to conclusion with my mechanic that it might be a faulty spark plug or spark plug coil.
We will try to find which one it is and we will see.
When I had EGT sensor down it just limped a lot and got back to normal after quick restart but did not shutter at all so I think it is not EGT this time.
I changed oil and all filters today and found out that fuel filter might have not been ever changed as it got extremely rusty - my mechanic could not unscrew it - will have to book like 2 hours with him next week to sort it out as he might need to cut it off. I heard Audi placed it in weird and complicated spot and that you need to get fuel tank down a bit to replace filter...
Anyway I do not think it was caused by clogged filter but we will check that as well.
Blue_Thunder
Post by Blue_Thunder » Fri Apr 24, 2009 9:02 am
Would a faulty spark or coil not make the engine shudder all the time?
Nige_RS4
Post by Nige_RS4 » Fri Apr 24, 2009 9:46 am
Is your car std, as I thought even standard RS4's went above 300g/s?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
carlosfandango
Post by carlosfandango » Fri Apr 24, 2009 1:37 pm
I have had the same problem, changed plugs, serviced changed the exhaust sensors and was still the same, at first I did not have any errors on VAG but then it showed a missfire on 4 so we changed the coil pack and that has made a big difference. The car is still not 100% right so I think I need to change all the coil packs. I also have been wondering about the Fuel filter.
jimbo1234567
Post by jimbo1234567 » Fri Apr 24, 2009 2:13 pm
itll be the maf. dodgy dave had the same problem a long time ago. just try disconnecting the maf plug and going for a run, it wont harm it. also have a read here
http://www.rs246.com/index.php?name=PNp ... highlight=
AndyC1982
Post by AndyC1982 » Fri Apr 24, 2009 4:14 pm
Hi there
I have been having the exact same problems, I thought it was the coil pack so i changed that out but i still have the same issue, i have came to the same conclusion as Nige, it is the probe down to the spark plug. I have just recieved it from audi and i'm changing it out this weekend so i'll update you if it helps
Regards
Andy
AndyC1982
Re: RE: Weird Shutter at 3-4k rpm when floored
Post by AndyC1982 » Fri Apr 24, 2009 4:18 pm
jimbo1234567 wrote:itll be the maf. dodgy dave had the same problem a long time ago. just try disconnecting the maf plug and going for a run, it wont harm it. also have a read here
I changed out the MAF as initially i thought the same as Jimbo but your issue sounds alot like mine, i would change out the plugs it should be obvious which one has the issue, then change that coil pack and probey thingy (sorry to get all technical!!! LOL)
Users browsing this forum: No registered users and 98 guests
